Question about Cub Cadet Garden
My Cub Cadet 7194 which would go through a battery annually.Periodically I can not get the engine to turn over or if I turn it off after running awhile it will not restart. What might be the problem?
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy;*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 12, 2009
SOURCE: cub cadet weed eater wont stay running
air vent in gas cap pluged, push a pin through it
Posted on May 28, 2009
  • 1111 Answers
SOURCE: Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Posted on Jun 17, 2009
  • 86 Answers
SOURCE: Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Posted on Apr 10, 2010
SOURCE: 96 cub cadet 2140 with cummins onan 14hp
I have cummins cub cadet Onan Elite 140 engine shuts off after about 20 min and won't restart for half hour.
Posted on Jun 06, 2010
I was mowing I have a cub cadet series 1000 was running fine all the sudden shut down and will not start acts like it has no connection. Battery is new, but still cleaned terminals. Turn key nothing
Make sure your new battery is charged up first. New batteries will die sometimes. Make sure your cables are tight and clean and your starter could be at fault if all that work it won't turn over. Make sure your engine is not seized as well.
Jul 21, 2015 | Cub Cadet Garden
I have a z force s cub cadet. The battery is good. Tested and passed. the engine/started must work hard to turn over, but still won't catch. I will jump the tractor and it will start and run.
You may want to try to find a battery with a stronger amperage rating. Even if the battery passes if it is borderline for starting it new it may not be strong enough even if it's still okay for it's battery type.
Other causes:
A worn starter can cause this issue. If a few of the coils shorted the starter will work but require much more current to do the job
A bad relay/solenoid to the starter that doesn't allow enough current to go through can cause this.
Valves out of adjustment... especially on some Briggs and Stratton engines, it's a known issue that if the valves need adjustment the motor can require a lot of energy to turn over and can cause constant hard starts.
Mar 28, 2013 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Troulbe shoot charging system on cub cadet 582
is the battery just bad the only last a couple years for lawn mowers
Apr 07, 2012 | Cub Cadet Garden
Cub cadet riding mowe
is the mower making any sounds when u crank it or nothing at all?
Feb 07, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Jun 24, 2009 | Garden
Garden Logo
37 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
