Question about Dryers
Using this remote, how do you change the direction of the fan for a sommer setting?
Genie intellicode medallion
Genie is not compatible with Sommer. They will never sync.
May 17, 2014 | Sommer 4054v001 two-button garage door...
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
How to reverse the fan direction
most to all fans have a switch on the side of it where the pull things are its a little switch that has two settings up or down this typically controlls the direction of the fan. (note: some fans are not designed to change directions and they wont) check you manual or instruction booklet
Aug 11, 2009 | Minka -Aire Brushed Nickel Remote Control...
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Dryers Logo
23 people viewed this question
Top Dryers Experts
