Water coming out the door in rinse cycle - Washing Machines
  • Washing Mach... Master
  • 18,388 Answers
First thing to check is that you don't have a piece of clothing stuck between the door seal. I have had that with a commercial machine. A towel was causing the leak. If it does it on every wash, then either the door lock needs adjusting for tightness or you need a new door gasket.
Posted on Apr 17, 2017
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Aug 15, 2015 | AEG Washing Machines
Rusty water dripping on the inside of the door after rinse cycle
Pull the screws out of the door check to see if they are rusted run the machine the outer door panel off should be easier to find the leak
Mar 30, 2014 | KitchenAid Dishwashers
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
Soap in JetDry dispenser.
Unfortunately there is no easy way to completely get the detergent out of the rinse aid reservoir in one quick method, short of taking the inside panel off the door.
However, I would try a simple way to flush it out. With the door open almost al the way open, pour warm/hot water into the rinse aid fill hole and keep pouring until you start to get clear water coming out. The water will be flowing back out the fill hole you're pouring the water into and should just flow down the door panel into the dishwasher tub. Try to keep the door about 10-15 degrees up from all the way open to let the water get in the rinse aid reservoir.
Just pour the water in slowing so you don't agitate the mixture and you should be able to get it running clear in 5-10 minutes. It could take a gallon or so of warm/hot water to accomplish this, but it will flush it.
When you'r done, just put the dishwasher into a rinse cycle to pump out the water and soap, etc. You may have to run a full cycle afterwards to get rid of any excess detergent in the tub.
Hope this helps and best regards!
Aug 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water drips out of front door
There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Dishwahser rinse cycle running for hours
It sounds like a thermal stop. The water in the rinse wants to get up to a certain temp to satisfy the thermistor but doesn't reach it so it will stay there. If you have an amp probe you can put it on to see if the heater is coming on. This could be your problem.
Sgt 48
Jun 17, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Ge washing machine
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Sep 20, 2007 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
