Question about Vacuums
Lack of suction
I have cleaned filter, taken off elbow in back (not clogged). Motor runs fine but almost no suction at all.
  • 100 Answers
You don't say what type of vacuum but it still sounds like a blockage or a split in a pipe... have another thorough look..
Is exhaust air blowing out of the machine... Is the motor running at a higher pitch than normal...?
Posted on Apr 17, 2017
Why does (it) have very poor suction?
The filter can be clogged but look clean. Most models have two filters. Replace them both every few years.
Jan 30, 2016 | Rainbow E series Canister Wet/Dry Vacuum
The vacuum has a lack of suction compared to when we bought it 6 months ago
Clean all filters and if there is a hose it could be partially plugged as well. Take hose off and shove something like a dry water hose through it.There is usually a filter back of the dirt bag as well. If it has been used to vac up drywall dust the dust bag will plug up before its filled as the dust is so fine it will plug up every thing on the vac. Really clean every thing and it will work better.
Apr 12, 2015 | Vacuums
I turn on the vacuum and it does nothing but when i put the brushes down is turns on and the brush motor runs.....but the suction motor won't do!
You have power so it can't be the switch or power cord. It is most likely the motor or the cord from the switch to the motor that is the problem. Start by checking these areas first.
Mar 29, 2015 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Miele S3141 canister began acting strange this morning. No I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Why would the vacuum have no suction?
if the motor is running it could be a belt a clog or a hole somewhere else in the hose
Feb 16, 2012 | Kenmore 23612 Progressive PowerMate Bagged...
No suction
OK - Details details details.....
If the motor turns on and only sucks a little bit or you are experiencing a great loss of suction,.
You have a plug somewhere
Be it a partial block from say a HEPA Filter
or else it is a block in the path of travel where items get sucked up into your vacume.
If you look back to the last time someone used it, was it a fine powder which was cleaned up? then look to the filter (see owners manual for maintenance and or cleaning of the vacume machine) Otherwise is it possible that someone else used it and get it clogged with something larger? Although I'm thinking it is the HEPA filter needing cleaning...
The good news is that if the machine turns on, then you know you have a block somewhere in it, bottom line is you will need to find the clog and you'll be back up and running in no time.
Best regards
Jan 05, 2011 | Hoover Elite Rewind Bagless Upright...
No suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Jun 19, 2009 | Dyson Vacuums
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the can use a coat hanger to push out the clog if there is one just bend the tip till its it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
