Question about Exercise & Fitness
Replaced incline motor on treadmill was stuck on incline 12 put new motor in and it went right back to incline 12 and stayed there what now? I spent 160 on this new motor and getting the same results
    Novelist:
  • 145 Answers
Hi There,
This person installed a new lift motor and had the same issue, so another new lift will do the same. What make/model of treadmill?
Lift commands come from the console to the lower board. Precor and some others use a Triac circuit to provide 120vAC for up or down, these parts can fail on the lower and cause this problem. Johnson Brands like Matrix, Vision, Horizon, Merit and others, use a relay set for up and down also commanded by the upper board.
I have seen upper boards cause this very problem. Contact jatinah@rocketmail.com for more help if needed. Good Luck
Posted on Apr 18, 2017
jgwhomeequip
  • 1902 Answers
SOURCE: The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
Posted on Feb 21, 2009
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
  • 6 Answers
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
Posted on Mar 25, 2010
  • 13 Answers
SOURCE: Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Posted on Jul 29, 2010
My HEALTHRIDER H95T treadmill is stuck in the fully elevated (level 12) angle on the platform and will not move
The incline motor is jammed due to a faulty incline sensor or incline motor assy. This is somewhat hazardous if you do not know what you are doing to remove the incline motor. Sometimes you can repair it most of the time you replace the incline motor assy. Must be calibrated upon completion.
Feb 22, 2015 | HEALTHRIDER H95T Treadmill
Incline motor ran away, won't work after replacing
see the diagram attached and test test the input motor voltage, if there are the motor is faulty.see my personal TIPS.
God bless you
Nov 18, 2012 | Proform XP 580 Crosstrainer Treadmill...
Epic Comfort step 425mx treadmill that we have is stuck on incline. How do I get it to go back down?
This happened to my treadmill. You need to get to the motor and see if the belt is fraying. If so, the fibers may have gotten entangled in the motor causing it to stay at the highest incline level. Once you clear this the treadmill will go up and down again. Hope this helps!
Dec 27, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Jul 25, 2010 | Icon Epic T60 Treadmill
Treadmill stuck on highest incline....and motor running...but seems stuck...won't come down
If the incline is stuck, it could be a problem as simple as the gearbox on the motor being jammed. Unplug the treadmill remove the motor shroud then remove the incline motor from the treadmill, reconnect the wiring, plug in the treadmill and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor. . If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power, you need to replace the board.
May 17, 2010 | Proform 650 Crosstrainer Treadmill
My nordic track treadmill won't decline
My wife had the same problem with her treadmill. I turned the beast on it's side, and unscrewed the plastic casing that houses the motor, computer, and all the electronics to the treadmill. I unplugged the incline/decline motor. Then on the bottom of the treadmill the long threaded rod that causes the incline needed to be moved. So I unbolted it from the catch, and manually screwed the rod back in with a wrench. Now the treadmill works fantastically, of course the incline/decline mechanism has been disabled, but I would rather have a treadmill with the incline disabled than have one always on 100% incline. Hope you found this helpful :)
Jan 05, 2010 | NordicTrack Exercise & Fitness
My treadmill is stuck at the highest incline and will not decline
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Dec 31, 2009 | Proform Quick Burn Pro Treadmill with 12...
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Feb 21, 2009 | Epic View 550 Treadmill
Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Jan 08, 2009 | Exercise & Fitness
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
