Question about The Computers & Internet
The keyboard that removes does not work
Dell keyboard wont work
Did you mean "Del key" does not work anymore? Basically, if one or more key does not work anymore, it means the keyboard is dying and you need to replace the whole keyboard (it is affordable and more efficient). You can visit and search the replacement keyboard using keyword "your exact laptop's model" + "keyboard". Later you can download the laptop's service manual, so you can do it by yourself if you would.
Mar 08, 2014 | Sony VAIO Computers & Internet
Keyboard not working
you will have to replace the keyboard. the keyboard normally gets fitted with one or mostly 2 screws from the bottem of the laptop and the keyboard is held by small clips
Sep 30, 2013 | Samsung R440-JT01
Keyboard stopped working, tried it in notepad, tried removing battery,
Check in the Device Manager for the Keyboard presence. If the keyboard does not appear it means that the keyboard doesn't commuicate with the mainboard anymore. If the keyboard appears installed and ok in the device manager, open on-screen keyboard from accesibilty and press every button on the keyboard, you should see on the computer display if any of the buttons work. If some buttons work and others don't it means that your keyboard is broken and only service can help you.
Nov 02, 2010 | HP NB199UA Pavilion Notebook
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
My Microsoft Wired 600 keyboard has suddenly malfunctioned and the keys "1" "Q" "A" and "Z" (as far as i know these are only ones) just wont work anymore, help?
Well, it's in a bad shape, but if you still wanna fix it, try remove all the nuts, then see for the rubber connector inside it, clean it with soft cloth and alcohol, then on the electronics board, clean it with it too.
Also recheck the PS2 connector ( if using PS2 ), sometimes this cause the problems.
Oct 23, 2009 | Microsoft Wired Keyboard 600
I try to use the flap keyboard and it s just not working at all.
i think so u r key board cutted so pls check it for a mechanic
Jul 01, 2009 | Sony Ericsson P910i Cellular Phone
Keyboard buttons
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Hope this will help some. Bud
Nov 22, 2008 | Computers & Internet
W key not working
Apparently whatever the manufacturer is using for a conductive material reacts with the air to form an oxide or film that interferes with conductivity. This is not a permanent solution to an engineering problem. I have several times taken the keyboard apart (little screws on the back), removed the bubble plastic layer, pealed back the layers and then wiped the "electrical key contacts" with a cotton cloth dampened with isopropyl alcohol. Put it back together and problem fixed-- for a while.
I think i've worn enough of the very thin material off that I can't do that anymore. Which is why I ended up here. Good luck.
May 03, 2008 | Microsoft Comfort Curve 2000 Keyboard
GE wireless keyboard - how to uninstall
all you need to do is plug in a normal keyboard & mouse and will work fine without removing your old drivers. but if you really want to go into control panel and add/remove programs and look for keyboard related program in the list. All the best John
Dec 25, 2006 | GE Optical Mini Mouse ho98094
Computers & Internet Logo
65 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
