Question about Cell Phones
I can not get wifi to work on my phone - Cell Phones
Cant get wifi to set up
WOW Dave Johns... Now that's what I call a question...!!
Unless your wifi is specifically designed to be "set up" by a cell phone... It is not likely you will succeed...!
(or maybe you were wanting to set the phone TO the wifi (huh?))
What color is the cell phone...?
What country... (802.11??... GSM, CDMA... what?).
Lets get all wild...
How about a full disclosure on the wifi,
brand, model... (has it ever worked = green lights)
Cell phone... BRAND, MODEL (has it ever worked)...
and which are you attempting to "SET-UP" on what...?
If the wifi is broadcasting... go to settings on the phone, muscle your way into your options, functions... see if you can find "wifi"
Search for available signals... and try to connect.
If it is secured... this is when you must enter the SECURITY CODE
Carnac the Magnificent
Jan 04, 2017 | Cell Phones
Why has my mobile phone WiFi stopped working at home?
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps
Jun 11, 2014 | HTC Cell Phones
My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Mar 05, 2013 | Cell Phones
Sony ericsson w890 wifi not working
Check weather any other device can detect wifi signal of your modem router. If it cannot detect the signal then it may be the complaint of your modem roter wifi.
If the other device can detect wifi of your modem router then back up the data of your phone and reset it. It will work fine.
Thank you
Jun 04, 2012 | Sony Ericsson W890i Cellular Phone
SE xperia x8 shows connected to wifi but not able to browse and doesnt open webpage..I can connect my laptop to the hostel wifi so its in a proper working condition.Please help.
Goto wifi settings of your Sony Ericsson X8 Android Mobile
press menu button and select "Advanced"
Disable the "Use Static IP" (please be confirmed that DHCP server runs on your router)
Courtesy: sivaramalingamk@gmail.com
Mar 23, 2012 | Sony Ericsson XPERIA X8 Cell Phone
I lost my phone and a friend had a galaxy from samsung, I activated my new sim&its been hours and my phone says im mot connected to a wi.fi network. How do I fix it and get my phone to work?
Go to a StarBucks or McDonalds. They have free Wi-Fi.
You can connect to the WiFi and then your phone will work.
Some phones need WiFi to work. If you have internet at home, just get a ROUTER with WiFi and you will be able to connect. Router are real cheap these days, some about $10-$15
and you can also find them on craigslist too
Good Luck & Happy Free WiFi calling!
Sep 17, 2011 | Cell Phones
I have a samsung galaxy gt-i9000 but my wifi nolonger works when i turn it on it says unable to scan twice then turns itself off.
Hello there,
You will need to be sure that there is wifi turned on in the area that you are trying to use your phone.
Then you try to go through the wifi list on the phone and delete all the wifi that it has ever seen and worked with. Then you turn off the phone for about 5 minutes, then you turn it on and turn on the wifi on the phone and search for the wifi available, that way it will search for the available wifi and connect to it.
Thank you for using fixya Caseytech
Jul 05, 2011 | Samsung Galaxy S GTI9000 Smartphone
I unlocked my iphone to work with t-mobile and now the wifi doesnt work, and it did when the phone wasnt activated, but now there is an E where the wifi should be
Your iPhone is probably just ignoring whatever WiFi networks you are nearby to right now since it now has access to EDGE (that's what the E means). Have you tried going to settings>wifi and searching for available wifi networks? If any show up then your wifi is working just fine.
Sep 30, 2008 | Lands Phones
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
