Add numbers - Office Equipment & Supplies
Add my phone to my facebook account?
From your computer, you can go to your Mobile Settings to add, remove or edit phone numbers.
If you already have a mobile number on the account:
  • Click Add another mobile phone number to activate another number
  • Click Remove to remove any of the numbers that are already listed on your account
Feb 14, 2015 | Facebook Computers & Internet
What to numbers can you multiply to get 280 and add to get-18?
When you say "to numbers" I assume you meant "two numbers."
There is no solution.
For the product of two numbers to be 280, either both numbers must be positive or both numbers must be negative. For the sum of two numbers to be -18, one or both numbers must be negative. Taken together, both numbers must be negative.
We can find two numbers that multiply to 280 and add to +18, then simply take the negative of both numbers.
The square root of 280 is about 16.7. The sum of any two numbers that multiply to 280 must be at least twice that, or at least 33.4. Since 33.4 is greater than 18, there is no solution.
If you want to do it the hard way, take any pair of negative numbers that multiply together to 280, add them together, and see how close you come to -18. For example, -1 and -280 add to -281. -2 and -140 add to -142. -4 and -70 add to -74. -5 and -56 add to -61. -7 and -40 add to -47. -8 and -35 add to -43. -10 and -28 add to -38. -14 and -20 add to -34, which is as close as you can come in the integers.
Jun 25, 2014 | Office Equipment & Supplies
Nokia lumia how to add contacts?
Follow these instructions to add new contacts on your Nokia Lumia
  • On Start, swipe across and tap People.
  • Tap the New icon (+) at the bottom.
  • Tap Name to add First name, Surname, Title, Company name etc then tapSave.
  • Tap Phone to add a contact number and tap Phone number type to choose the type of number then tap Save.
    If you wish to add further information such as an additional phone number or an email address, tap to add more details or press Save to store the contact to the People Hub.
May 05, 2014 | Cell Phones
How do you delete and add speed dial numbers
Push star on all the numbers then add the numbers you want and push add.
May 09, 2012 | Clarity Professional C4105 Amplified...
Hi i want to block number to call me ,my phone is nokia 1280
You can not block that number.Your mobile will not support for that.
* You can do one thing.You can add that number to the screened list.
* If you add means your mobile will not ring if that person calls you.
* Their you will see the miss call information.
* If they send you message means it will be stored in the screened message.
* If you want to add that number means you should follow this steps.
* If you have miss call from that number means select that number there you will be having option select that option.
* There scroll over to add to scrn.list select that one.
* Then it will ask do you want to add this number to screened list.
* Select it.
* From now you wont get ring if that person call you.
* Message will be stored in screened message.Select message scroll over to screened message.In that you will find the message.
Thanks for your question.
Jun 27, 2011 | Nokia 1280 Cell Phone
Out of 1,3,5,7,9,11,13,15,17,19 pick up any 5 nos. to make a total of 50.
Several ways to do this. 1, 5, 13, 15 17 is one of them.
(1 x 5) + 13 + 15 + 17
(1 x 5) = 5
5 + 13 + 15 + 17 = 50.
- You cannot add five odd numbers together to make 50. Five odd numbers added together will always be an odd number.
- You cannot add four odd and take an odd number away as this will also total an odd number.
Therefore 2 of the numbers must be multiplied as this enables you to effectively add four odd numbers together to total an even number.
Hope this helps. Got any more?
Jan 13, 2011 | Vacuums
How do you add a phone number to the address book of a Uniden cor
Hello there and welcome to lfete at Fixya, the Support Team
Normally you add a new number to the phone in the feature contacts. Go to there and select add new and type the number name etc. :O)
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Jan 02, 2010 | Uniden Cordless Phone
Add mixed numbers
This image shows you on the quick guide where you can find the information.
Once you know how to interpret the results, you can add the mixed numbers as you would ordinary numbers.
Hope it helps.
Oct 28, 2008 | Texas Instruments TI-34II Explorer Plus...
Car radio code
Check put the peugeot GSi 6 site.
I read there trhat the way to locate the code is;
1) pull out the radio ( I had to get the metal "keys", named sony at Halfords)
NB the slots for the 1995 306 are underneath the facia.
2) from the two numbers on the bar code...take the LAST 4 DIGITS of the BOTTOM number
3) add the following numbers in sequence to them;
a) add 1 to the first number
b) add 2 to the second number
c) add 3 to the third number
d) add 4 to the last number
To input the CODE into the radio, you need to keep pressing the number 1 button UNTIL you see the first number of your code displayed ie press it 3 times if entering the number 3 from your code.
Then use the number 2 button to enter the 2nd number of your code
Then the number 3 button to enter the 3rd number of your code
Then the number 4 button to enter the LAST number of your code.
God Bless!
Apr 20, 2008 | Car Audio & Video
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
