Question about Samsung Televison & Video
I have a Samsung LED TV Model #UN50F6300AFXZA S/N Z6WF3CAD705384B. It seems that I have loss the backlights on my TV. I did the flashlight test and can see the picture when I'm shining the light
  • Samsung Master
  • 1,527 Answers
Hi getting quite common now the led in the panel my have shorted out, thanks
Posted on Apr 17, 2017
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
Samsung LED TV # LN52A860S2F audio NO PICTURE..has lights when I look threw the vents
Perform flashlight test to see if the problem is with the backlights inverter board.
Jun 15, 2017 | Samsung Televison & Video
My LG tv (Model number: 32LS3410-UB) has sound, but no picture. When I do the flashlight test I can see a very dark image on the screen. Will replacing the LED driver fix this problem?
If you already tested with the flashlight which is the first step in the blank screen with sound fault then you have to test the LED Backlight supply voltages if you are familiar and good in the electronic repair. First you have to check if bulging capacitors for the LED Backlight drive voltage circuit, replace them. If capacitors are good then you have check the backlight LEDs. The flashlight test proves that the power supply is good and TV is working fine because the sound is ok and picture is fine. Attached videos and links may help you for the repair and replacement of backlight LED strips or LEDs itself depending on the type of LED strips used in your model.
May 08, 2017 | LG Televison & Video
Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Aug 07, 2016 | Samsung Televison & Video
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
Feb 17, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
Jan 24, 2015 - Uploaded by
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
Dec 26, 2015 | LG Televison & Video
Samsung LED tv UN32EH4050FXZA No Backlight
Check ur led driver board and also a possible shortted led light
Dec 15, 2015 | Samsung UN32EH4050 32" LED TV 1366x768, 60...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Televison & Video Logo
46 people viewed this question
Jerry Greenberg
Jerry Greenberg
