Question about Pool & Spa
Lay-z-spa pump is leaking from the bottom of the pump. Also dripping from the connectors that atta ch to the pump. The two with the metal rings on them. Any solutions?
    Top Expert:
  • Pool & Spa Master
  • 6,889 Answers
Replace whole pump and leaking parts watch chemical levels
Posted on Oct 30, 2017
catriver
  • 878 Answers
SOURCE: Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. Catriver..post back.
Posted on Oct 23, 2006
SOURCE: I have Brew Station 47665. My coffee tank leaks.
contact 1800-815-8900 give model no. &serial no. under brewmaker bottom they have replacement part & info
47214 brewstation
Posted on Feb 27, 2009
polarcycle
  • 1392 Answers
SOURCE: Kawasaki Oil Pump Leak
Bad seal in the pump itself. It is like a weep hole in a water pump. It is letting you know it is time to be replaced.
Posted on Jun 10, 2009
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
Coastsider
  • 331 Answers
SOURCE: water is pouring out the
It is possibly coming from the heat exchanger. Most heaters have a copper tube style exchanger, capped at each end by plastic or metal headers. If the tubing has been subjected to any corrosive water condition such as low PH, low calcium hardness or very high cyanuric acid levels, the tubing may have deteriorated and is leaking. You may have dismantle the heater further and check for leaking.
Posted on Sep 10, 2010
Hi everyone my coleman lazy spa leaks from pump is there a way to fix this?TIA
looks like this has a magnetic drive pump and are not common to leak. so disassemble and locate loose or cracked part and try silicone or epoxy to do the repair. I recommend Majic lube for rubber o-rings and gaskets Lay Spa Teardown
Jun 18, 2017 | Pool & Spa
Lazy spa pump leaking from the base
as the seals leak they ruin motor bearings replace whole unit less hassle
Nov 09, 2017 | Pool & Spa
Lay z spa pump leaking
Shaft seal appears to have failed - replace it?
Have a service provider in your area check it out if you feel you can't move forward with this.
May 19, 2014 | Pool & Spa
Leaking lay z spa pump
Firstly try some Fix-a-leak spa leak repair.
If the suspected leak is less than 1/8" that should fix it.
Or remove the paneling to find where it is coming from, there is no easy solution.
Jul 25, 2012 | Pool & Spa
I have a leak at the bottom of the pump were the o ring is. The leak is a slow drip and the oring looks good
this is very common with these pumps. you can try replacing the o-ring. the tolerances are very close so it's best to use a new o-ring and use plenty of lube when installing. don't over tighten the bolts.
Oct 28, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pump is leekin water
there are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Sep 16, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Water is pouring out the bottom vent of the lay z spa heater have taken apart but cannot find where the water is coming from it only seems to do this when the pump is on
Sep 05, 2010 | Pool & Spa
I have just purchased an fzr 250 that has been dropped or crashed at a low speed and a metal pipe that is going into the water pump is leaking at the seal going into both the engine and the pump itself....
replace the pipe, they have an o ring seal, and it probably doesnt sit square and will always leak. dont risk overheating the engine, the leak may get worse while you are riding as pressure builds in the radiator. you might do a quick fix with new o rings
Apr 11, 2010 | 1988 Yamaha FZR 250
Pool & Spa Logo
628 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
