Question about KLH Audio Players & Recorders
Connecting my Advent AS2 speakers to my KLH amp
2 Suggested Answers
  • 6771 Answers
SOURCE: I'm trying to run advent as2 speakers with a kenwood vr5900 receiver but they are clipping
You can not do that, it will result in catatrophic failure in the output stage which will prove very costly if you continue.
Posted on Mar 29, 2012
I have a pair of KLH AV5001 speakers and I have them hooked up, there is sound but it's distorted and there's zero base, an instruction manual or any advice would be great, thank you.
Without knowing what they're hooked up too.. SOUNDS like your uder powering them, OR over powering them. Look at the back of the speakers the wattage is what your looking for, look at your amp, example: 1000w speaker running on 50w amp = not good.
Jul 05, 2016 | KLH Audio Players & Recorders
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
How to install KLH asw10-20 to a 7.2 receiver
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
Jan 20, 2015 | KLH Audio Players & Recorders
How do I hook up klh 2503 speaker system
You need a stereo receiver or Hi-Fi amplifier to drive these speakers.
The amp or receiver will have red and black speaker terminals to match up with the speakers. Use some speaker wire to make the connections.
Once the amp and speakers are connected, you can add a source. The source could be your PC, TV, games console, MP3 player.
Aug 09, 2014 | Audio Players & Recorders
Mar 29, 2012 | Recoton Advent Advent AS2 Main / Stereo...
Need a product manual for a klh 9906 home theater system with 4 satellite speakers a center speaker and a bassbite II
Try the KLH site. I have downloaded (for free) info on KLH products. Not much on technical stuff, but set up info and connections.
Jun 12, 2010 | KLH BB-II Subwoofer
Instructions on how to hook up outdoor speakers to computer
Get a set of wireless speakers (such as Advent AW-820 900 MHz Wireless Stereo Speaker System).  Connect the transmitter to the earphone jack of your computer.
May 20, 2009 | KLH Audio Players & Recorders
My klh subwoofer has R&L connections to speaker and R&L connections to amplifier, but my new amp has a RCA cable connection plug-in. Any way I can use the old subwoofer with the new system?
Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
Jan 01, 2009 | KLH ASW10-120 Subwoofer
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
