Question about Plumbing
Pentax water pump cam 100/00, water inlet & outlet and how to hook up plumbing
dcp2
  • 63 Answers
SOURCE: us style fridge/freezer plumbing re water/ice dispencer
Most of them are in the back left side. Its only about 1/4 inch line that is used
Posted on Jan 28, 2008
  • 39 Answers
SOURCE: bosch dishwaser
Hi francoisj
There might be water in the bottom pan under the dish washer. first turn off the power, then take the kick plate off and you should be able to feel if there is water in there. If there is remove all of it. you can do this one of 2 ways useing paper towel or my pulling out the dishwasher and tipping it 45 degrees. i recomend trying papertowel first and that should get you going again. hope this helps
brent
Posted on Sep 29, 2008
appldoctom
  • 311 Answers
SOURCE: a small drip on front side where water comes out of machine
thats your pump. if it leaks all you can do is replace to solve problem.thats the white resvoir looking thing,its a pump
Posted on Jan 10, 2009
woobie dog
  • 1273 Answers
SOURCE: water inlet, outlet,ok start engine lose all
Prime the pump well by connecting the water and letting it run for several minutes to get all traces of air out of the pump.
Regards, --W/D--
Posted on Jul 20, 2009
  • 28 Answers
SOURCE: How do i hook up the water supply. witch is the
Most newer units have a brass inlet on the valve and a plastic outlet. Older modles have a plastic garder hose type fitting for inlet and same smaller plastic thread for outlet Some models have push in connectors called John Guess fittings the do not require threading.
Posted on Sep 27, 2009
Im on tank water using a onga pump, loss of water pressure at taps,how do i get it back tanks full, whole system is only 6mths old,thanks
check for a blockage at the pump inlet or outlet from the tank
(leaves, animal etc)
check that the motor is running at full rpms ( problem start/run capacitor--no guaranteed life of capacitor)
check for water leak after pump
Mar 31, 2016 | Plumbing
Can you hook both heater hoses to the intake i put a 85 chevy 350 in it no were to hook on water pump
One exits the thermostat housing and the other needs to enter at a different point, usually the water pump.
Nov 04, 2015 | Cars & Trucks
How to hook up a Water Workers vertical well system pressure tank HT86B to a Craftsman hydroglass convertible deep well jet pump 390.252283
Look at this photo
http://www.freshwatersystems.com/images/Product/medium/5470.jpg
You must have the pressure switch and some form of a Tee fitting. The Tee fitting shown is made especially for pressure tanks. It has the 3/8" side threads to properly connect the pressure switch, pressure guage, 1/2 or 3/4 thread for silcock and over pressure relief valve, and typically 3/4 or 1" inlet and outlet (where the ball valve is). I also recommend a union on either side so you can remove the tank without having to cut lines in the future. The order doesn't matter. Water will come up from the pump, building pressure in the tank (it has an air bladder inside), until the pressure switch cuts power.
May 01, 2014 | Water Worker G12 - 4.4 Gallon Thermal...
How do you install a thermostat on a 2001 suburban?
  1. Standing in front of the vehicle it's on the left front side of engine kind of low.
  2. Be sure to get a gasket as well.
  3. Drain the cooling system.
  4. Loosen the air cleaner outlet duct clamps at the following locations:
    • Throttle body
    • Mass airflow/intake air temperature (MAF/IAT) sensor
  5. Remove the radiator inlet hose clip from the outlet duct.
  6. Remove the air cleaner outlet duct.
  7. Reposition the outlet hose clamp at the water pump.
  8. Remove the outlet hose from the water pump.
  9. Remove the water pump inlet bolts.
  10. Remove the water pump inlet and thermostat from the water pump. Water pump inlet/thermostat assembly location
To install:
  1. Install the thermostat and water pump inlet to the water pump.
  2. Install the water pump inlet bolts.
  3. Tighten the water pump inlet bolts to 11 ft. lbs. (15 Nm).
  4. Install the outlet hose to the water pump.
  5. Position the outlet hose clamp at the water pump. NOTE
    Important: Align the arrow at the throttle body end of the duct with the throttle body attaching stud.
  6. Install the air cleaner outlet duct.
  7. Install the radiator inlet hose clip to the outlet duct.
  8. Tighten the air cleaner outlet duct clamps at the following locations:
    • Throttle body
  9. Tighten the air cleaner outlet duct clamp screws to 62 inch lbs. (7 Nm).
  10. Fill the cooling system and check for leaks.
Read more: http://wiki.answers.com/Q/Where_is_the_thermostat_located_on_a_2001_chevy_suburban#ixzz1TvIO3kpD
Aug 03, 2011 | 2001 Chevrolet Suburban
Where is the water pump gasket or the thermostat gasket in a 2002 cadillac escalade?
Thermostat Removal & Installation 4.8L, 5.3L and 6.0L Engines To Remove:
CAUTION
The thermostat is not serviceable separately. The thermostat housing (water pump inlet) and thermostat must be replaced as an assembly.
  2. Remove the bolts from water pump inlet.
  3. Remove the water pump inlet from the water pump.
To Install:
  1. Install the water pump inlet to the water pump.
  2. Install the water pump inlet bolts. Torque to: 11 ft-lbs. (15 Nm)
  3. Install the radiator outlet hose.
8.1L Engines To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
    • Inlet hose from the water outlet Water outlet and thermostat removal chevy_sub25_02-04_60_thermost_rem.gif
    • Water outlet bolts (B)
    • Water outlet (A)
    • Thermostat (C)
To Install:
  1. Install or connect the following:
    • Thermostat
    • Water outlet
    • Water outlet bolts and tighten the bolts, Torque to: 22 ft-lbs (30 Nm)
    • Inlet hose to the water outlet
  2. Fill the cooling system.
  3. Test drive the vehicle to confirm the repairs.
Nov 09, 2010 | Cadillac Escalade Cars & Trucks
We commenced using our Onga water pump some time ago after a long period of inactivity. It went very well at first providing good pressure to several outlets now however the pressure has gradually...
It appears that the pump is not running at full capacity due to a restriction either in the inlet or outlet pipes. If there is a gauze filter in the inlet it may be clogged. Also check the non return valve on the inlet side to ensure it is moving freely and sealing properly as it could be worn and restricting the flow.
Sep 17, 2010 | Omega Plumbing
How to replace a water pump on a 2003 yukon
Water Pump Replacement (4.8L, 5.3L and 6.0L Engines)
Removal Procedure
1. Drain the cooling system.
2. Loosen the air cleaner outlet duct clamps at these locations:
 Throttle body
 Mass Airflow/Intake Air Temperature (MAF/IAT) sensor
3. Remove the radiator inlet hose clip from the outlet duct.
4. Remove the air cleaner outlet duct.
5. If necessary, remove the engine sight shield.
6. Remove the radiator vent inlet hose from the radiator hose clips.
7. Reposition the inlet hose clamp at the water pump.
8. Remove the inlet hose from the water pump.
9. Remove the fan blade.
11. Reposition the outlet hose clamp at the water pump.
12. Remove the outlet hose from the water pump.
13. Reposition the surge tank outlet hose clamp at the water pump.
14. Remove the surge tank outlet hose from the water pump.
15. Reposition the heater inlet hose clamp at the water pump.
16. Remove the heater inlet hose from the water pump.
17. Remove the water pump bolts.
18. Remove the water pump and gaskets.
19. Discard the water pump gaskets
Installation Procedure Important: All gaskets surfaces are to be free of oil or other foreign material
during assembly.
1. Install the water pump and NEW gaskets
2. Install the water pump bolts.
3. Install the heater inlet hose to the water pump.
Zoom Sized for Print
Notice: Refer to Fastener Notice in Service and Precautions.
2.1. Tighten the bolts a first pass to 15 Nm (11 ft. lbs.).
2.2. Tighten the bolts a final pass to 30 Nm (22 ft. lbs.).
4. Position the heater inlet hose clamp at the water pump.
5. Install the surge tank outlet hose to the water pump.
6. Position the surge tank outlet hose clamp at the water pump.
7. Install the outlet hose to the water pump.
8. Position the outlet hose clamp at the water pump.
9. Install the accessory drive belt.
10. Install the fan blade.
11. Install the inlet hose to the water pump.
12. Position the inlet hose clamp at the water pump.
13. Install the engine vent inlet hose to the radiator hose clips.
14. If necessary, install the engine sight shield.
15. Install the air cleaner outlet duct
16. Install the radiator inlet hose clip to the outlet duct.
17. Tighten the air cleaner outlet duct clamps at these locations:
 Throttle body
 MAF/IAT sensor Tighten the clamps to 7 Nm (62 inch lbs.).
18. Fill the cooling system.
I hope this helps. The numbering is incorrect in the sequence but the instructions are correct.
Roy
Nov 06, 2009 | 2003 GMC Yukon
Pressure washer - no water flow
Is there a check valve on the hose inlet that is stuck, and won't let the water in???????
May 25, 2009 | Plumbing
Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
May 10, 2009 | Hayward SAND FILTER, PRO SERIES
Plumbing Logo
64 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
