Question about Coffee Makers & Espresso Machines
Upper Burr is stuck and can not remove it - Coffee Makers & Espresso Machines
3 Suggested Answers
SOURCE: the upper burr stuck upside down!
Yes, this butter knife trick is the way that Capresso customer service recommends. Just to clarify the tip of the butter knife is the only portion inserted...DO NOT shove the entire blade into the grinder. Just the tip in the furthest to the right side of the "smiley face ****" that is on the top of the grinder without the clear plastic hopper. just imagine a birds eye view. Once you have the tip of the butter knife all the way to the right of the "smiley face ****" then just rotate counter-clockwise until it does not go any further. This should have dislodged the top part of the grinding cone and then simply pick it up with your fingers, flip 180 and put it in the correct way.
Posted on Jul 20, 2010
SOURCE: Hmm, I have Capresso Infinity Burr Grinder #560,
Yes! I had the same issue with putting the burr in upside down and then twisting it an effectively "locking" it in there incorrectly. I tried the "knife" solution that worked for some people here, but it was placing the bean container back on and twisting counter clockwise that did the trick!
So glad I found this thread and didn't give up trying to fix my burr grinder (which we love).
Thanks to jaybayca!
Posted on Aug 20, 2012
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
Tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
on Aug 12, 2010 | Coffee Makers & Espresso Machines
How to change burrs
1 take the bell(bean container) carefully out. 2 disassemble the upper holder of burr 3 you will see now the burrs, clean good coffee remains than disassemble the burrs 4 after disassembling burrs clean good the lower and upper burr holder. 5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Feb 11, 2011 | La Pavoni Jolly (PA-JL) Electric Burr...
Hmm, I have Capresso Infinity Burr Grinder #560, and I accidentally placed the upper burr back in upside down. Now it is stuck. I do not see the "black section with a long slot" around the blade.
Thanks to jaybayca!
Jan 08, 2011 | Jura Capresso 560 Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
Rocky has a tumbling (unbalanced) sensation when grinding you can feel and hear. Seems less if you back off grind # to 20 from 8. Been using 8 for a year with no problem before today.
  1. take the bell(bean container) carefully out.
  2. disassemble the upper holder of burr
  3. you will see now the burrs, clean good coffee remains than disassemble the burrs
  4. after disassembling burrs clean good the lower and upper burr holder.
  5. carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly,
  • if it is ok you will have complete circle
  • if it is deformed you will have incomplete circle( that you must compensate with letter tape )under the burrs you apply the letter tape
  • after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Aug 20, 2010 | Rancilio (RAROCKYND) Grinder
Can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Jul 12, 2008 | Gaggia MDF Coffee Grinder
Rocky Calibration
  1. replacement of burrs after 500 kg grinded coffe
  2. if upper burr holder and the body of grinder does not hold stabile, teflon aplying does not help too much, it is only temporary solution. new upper bur holder would do better.
  3. before inserting upper burr holder you should check if lower burr is rotating syncronized, you should take a bit chalk and sof touch while burr rotates. after that you stop grinder and look do you have circle with same thiknes, that would give you idea where is the problem, if it is in lower burr.
Apr 07, 2008 | Rancilio (RAROCKYND) Grinder
Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Mar 13, 2008 | Krups GVX2-12 Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
