Question about Refrigerators
ICEMAKER,, WILL NOT WORK, WILL NOT FILL UP THE ICE CONTAINER
catriver
  • 878 Answers
SOURCE: Ice Maker
Charles, these models have a habit of the inlet tube freezing over. Make sure the black tube feeding the trough is clear. You may want to disconnect it from the back and see if you can blow through it. I use hot water in a baster to clear them all the time. Another thing is to check the optics. When opening the freezer door the red optic light on the right should flash 2x with a pause repeatedly. When you close the left hand emitter flapper the light should stay on. If it does this your optics are good. Because of these optics the new ice-maker has to be jumped started into a cycle. Once started you can monitor the fill. Catriver..post back.
Posted on Aug 09, 2006
SOURCE: whirlpool fridge model WF-NL300 ice
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Posted on Feb 29, 2008
SOURCE: KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Posted on Dec 05, 2008
  • 1122 Answers
SOURCE: Ice maker won't dump
REMOVE THE FRONT PANEL FROM THE ICE MAKER,SEE IF YOU SEE ANY BROKEN GEARS,ALSO THERE IS A HEATER THAT HEATS UP BEFORE THE DUMP CYCLE TO LET THE ICE DROP OUT,THE BEST TO DO IS REPLACE THE ICEMAKER IF TYOU DON'T FIND ANYTHING,YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE ONE FOR AROUND $50,EASY TO INSTALL-MIKE
Posted on Mar 15, 2009
  • 358 Answers
SOURCE: My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Posted on Jul 14, 2009
Icemaker is making ice but will not dispense. continues to accumulate then over time ice in the bottom of the dispenser will freeze
I can think of two possible problems. The ice has frozen together and will not allow the ice screw to push the ice out the dispenser. Or the motor for the ice screw is broken.
1. Shut off icemaker with lever at icemaker
2. Remove ice container (either throw away ice or save in another container).
3. Put back empty ice container.
4. Leave ice maker off for about an hour.
5. After an hour , check if motor is working by trying to dispense ice. You should not expect any ice but you should hear the motor /auger moving.
A) If you do not hear any thing , you need to get your motor replaced.
B) If you hear the motor , mostlikely you had an ice dam which prevented the ice dispense from working..You can turn you icemaker on.
Oct 15, 2015 | Whirlpool Refrigerators
Ice Maker No Longer Working
The icemaker contains an electric motor. You might have drowned it.
Nov 13, 2013 | Kenmore Refrigerators
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I am looking for a schematic for the kenmore 51 lbs ice maker
There is supposed to be a cap or plug , at the bottom of the water bucket , to hold water for the recirculating pump . There is no cap at the bottom of the ice bin .
Sep 09, 2009 | Kenmore 51lb. Clear Ice Maker
My U-Line ice maker somehow leaks water inside the freezer and a layer of ice builds up on the bottom below and to the sides of the ice container. It continues to build until ice container is not...
You can have a couple of things causing this. First do you see flakes in the ice cubes? Yes replace the icemaker. No then I would remove the cover off the icemaker (pry on the corners and pull) Check to see if the motor gears is rusty. If yes then its causing the motor to run slow and overfillilg the icemaker. You can also check to make sure the fill tube is pointing downward in the water cup of the icemaker. If that looks goo then it cold be the matter of replaceing the faceplate of the icemaker. That would replace the switch, motor and gears.
Aug 16, 2009 | U-Line Icemaker
GE Icemaker stopped making ice. everything else
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
Kenmore side by side 253.54662400 makes hollow ice cubes - do not dump
yes i would replace the icemaker. it sounds like the heater and ejectors have lost their sync. could be caused by the internal drive motor.
Jun 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
