Question about The Optics
What does the error code F6 and E2 mean on a Maytag Bravos XL washing machine?
Model # MVWB835DW0
SOURCE: Get a "F51" code on
Go to http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
It shows what the codes mean. It's been fixed by people (when machines are out of warranty!) by taking the control panel, and reseating wires on it and the motor.
You are by no means the only having the problem:
http://worldofwashers.blogspot.com/search/label/f51
Posted on May 01, 2008
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Posted on Jan 11, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
Posted on Oct 22, 2011
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
I have a maytag bravos washing machine what does code f11 mean
Hello. The F11 error is a communication failure between the control boards. This error can be caused by the main board, motor control, both, or the wiring harness. I will need the complete model number to hopefully provide a more accurate diagnosis. This is usually a very INVOLVED repair. Hopefully, there is some sort of warranty, protection agreement, or coverage and I would advise having a tech come onsite to diagnose more completely.
Aug 24, 2015 | Maytag Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
How to replace bearing on maytag bravos washing machine
is it loud in spin if it is then change the bearings
Feb 02, 2014 | Whirlpool Washing Machines
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
I have an error code on maytag washer model # mtw6600tbo what does code mean
Error codes are given whenever the washer has a problem. Could be overuse of soap to overloaded clothes. Who knows? You ain't said what the error code is. Their are several styles of these machines. The Oasis, the Bravos, and the Cabrio are all tailored after the Fisher and Paykel washers. I have written a tip which features the error codes HERE
Jun 30, 2011 | Maytag Washing Machines
Optics Logo
65 people viewed this question
Top The Optics Experts
David Clark
David Clark
Lawrence Oravetz
Are you a The Optic Expert? Answer questions, earn points and help others
