Question about Refrigerators
My Wine 1224 door is closed but the alarm is on. Its not a door issue as I was sent by Uline some magnet to instal but without instructions its not a lot of help. Ideas?
4 Suggested Answers
  • 286 Answers
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Posted on Jun 15, 2009
  • 286 Answers
SOURCE: Describe your uline wine cooler Problem
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Posted on Jul 20, 2009
kel1guy2002
  • 3740 Answers
SOURCE: No instructions for installing new seal on door
Service and parts manual is here.
http://stroboflash.com/searayproject/Docs/U%20LINE%20Service%20Manual.pdf
The procedure is as stated in solution 1 by expert Ironfist. The older units had a metal plate with screws that you had to loosed the screws in the retaining plate by peeling the gasket in the opposite direction without tearing it to loosen or tighten the screws on the retaining plate. Then you just lifted the gasket off. When you go to reinstall as previusly stated by the other expert... start in the top center and work to the corners. Make the coners fit before moving down either side to the bottom corners. Again make the lower corners fit and finally install the gasket across the bottom. Once installed rub the gasket mounting area smooth with one finger or thumb.
You have humbled and hornored me with your request. If there is something that your really having difficulty with once you start this gasket change just repsond here and I will get back to you ASAP but, we will complete the task!
Thanks again,
Kelly
Posted on Jun 28, 2011
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
Dec 27, 2012 | Haier Aficionado 26 Bottle Wood Trim...
No instructions for installing new seal on door (Uline 75WC Wine cooler
Thanks again,
Kelly
Jun 28, 2011 | U-Line Uline Origins Series...
Alarm going off-says front door problem, but front door is fine. How can we stop alarm from going off?
If your front door is using a wireless transmitter then the problem is most likely a mis-aligned contact. Most alarm installers will install the transmitter with built in contact on the door molding and a small magnet on the door itself. There is generally an alignment mark on the transmitter case so you know where to place the magnet. The magnet should never be placed more than 1/2 inch away from the transmitter. Be sure the alignment is correct as well as within the spacing requirements. If this was done properly another possibility is either a defective contact or in some cases a loose fitting door with excessive free play could also be causing you a problem. Make sure the door is tight when closed. If your door contact/transmitter is of a different design such as an external contact wired to the transmitter let me know the specifics (type of contact ie., hidden press fit, plunger, surface mount) and I'll give you additional information regarding what to look for. I have over 30 years experience in the alarm business and am sure I can help you.
Aug 29, 2010 | GE Security Simon 3 Wireless Home Security...
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Uline wine cooler 2075wc doesnt work, light goes on ????
Nov 01, 2008 | U-Line 75WC Wine Cooler
Cannot close vinotemp
The bottles are too long, and its probably hitting the glass. Try installing without it being double deep and see if that works.
Aug 09, 2008 | VinoTemp (VT60GNV) Wine Cooler
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
