Model is ds6722-3
SOURCE: How do you leaving a voicemail for your answering machine on the Vtech cordless phone?
ARE YOU WANTING TO RECORD A MESSAGE THAT CALLERS WILL HEAR OR ARE YOU WANTING TO LEAVE A MESSAGE FOR SOMEONE YOU CALLED?
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: Change the number of rings - Samsung D500
This is a network related setting. Do the following.
from your home screen, type "* 61 * (voice mail access
number) ** (time in multiples of 5 ) #" and then press SEND. For
example, if my voicemail
access number is 404-555-1212 and I want it to ring for 20 seconds
before forwarding to
voicemail, I would type: *61*14045551212**20#
SOURCE: changing number of rings
If you would go to your phone and dial intcorm #6041 plus thevoice maik extension number than enter time in 20 for exemple is 5 ring before going to voice mail than hang up.
SOURCE: how do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
