My quietside air conditioner has H3 on the control panel, what is it?
  • 3 more comments
  • Denkichu
    Denkichu Apr 17, 2017
    http://prntscr.com/exbm1n
    Wiring terminal OVC-COMP is loosened. In normal state, the resistance for this terminal should be less than 1ohm. 2.Refer to the malfunction analysis ( discharge protection, overload) thats the info im seeing there seems to be an issue with the compressor itself such as overload protection so the system is shutting itself off to prevent damage to the compressor unit
    more info herehttps://www.manualslib.com/manual/811907... and on the screenshot as well
  • Paul STPierre
    Paul STPierre Apr 17, 2017
    Thanks for the info.
  • Denkichu
    your welcome
  • Paul STPierre
    Paul STPierre Apr 18, 2017
    I had the repairman in and found coolant was low. He also found a slow leak at one the connections, works perfectly now.
  • intellectualfreedom
    intellectualfreedom Apr 19, 2017
    I use the following method to reduce video file sizehttps://www.idealshare.net/video-convert...
    Master:
  • 507 Answers
Might i get the make and model of your AC to be sure which brand it is throwing the H3 error code?
Posted on Apr 16, 2017
Testimonial: "Thanks, mfg: Quietside model#; QS18-V3220 dual heat/cool, wall mounted 18000 btu (cool) 19800 btu (heat) thanks for inquiring"
I need to order a universal quietside minisplit remote
Hello, Rebecca -
Clarification:
Are you thinking you can order the remote control you need through Fixya.com? If so . . . you cannot. Fixya.com does not sell anything.
Are you asking where you can order the remote control you need? If so . . . the answer depends upon where you reside (what country.)
Fixya.com, a website intended for asking and answering questions about repairing _things_, receives questions from people located worldwide. Without knowing where you live, I cannot provide you with a list of businesses from which you can order the remote.
Instead, I suggest you conduct your own search, using your favorite search engine. I tend to use Google. Use this search strategy, with quotation marks as shown:
Quietside "mini-split" "remote control"
Most likely the website results listed near the top of the results will be sources through which you can order a replacement remote control.
Note: I hope I am correct in thinking you need a remote control for a Quietside (brand) mini-split heat pump, or, perhaps an air conditioner?
I am answering from the USA.
Best wishes.
Jan 18, 2018 | Universal Televison & Video
ZHF/LT-01 symbols
Following amazon item link can be compatible for your ZHF/LT-01
What's important is that it display in Fahrenheit.
Other ebay or amazon sellers sell replacement in Celsius
Amazon com Replacement for QUIETSIDE Air Conditioner Remote Control ZHF LT...
Jun 27, 2016 | Cell Phones
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
H3 code
is there any way I can fix an h3 code on my new air conditioner?
Sep 08, 2014 | Norpole 8000BTU Window Air Conditioner...
How to work the control of zhf/lw-15
Following amazon item link can be compatible for your ZHF/LW-15
Amazon com Replacement for Chigo Quietside Air con HRRM Air Conditioner...
Oct 11, 2013 | Turboair Heating & Cooling
Need to remote for AMCORAIRE ZHF/LT-01
Following amazon item link can be compatible for your Amcoraire ZHF/LT-01
Sep 20, 2012 | AmcorAire UCHW-H12AF2 Split System Air...
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
