Question about Troy Garden
I have a troy bilt tiller serial number 798194, can anyone give me the year of manufacture
5 Suggested Answers
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
Posted on Aug 06, 2009
  • 12 Answers
SOURCE: i have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Posted on Jul 27, 2010
davidwill83840
  • 268 Answers
SOURCE: I have a Troy Bilt rear tine tiller with serial
Call the dealer... they can run the model number and usually let you know
Posted on Nov 20, 2014
I have a troy bilt rototiller horse, serial #7146C. Can you tell me what year it is?
Go to the Troy Built web site, find the contact phone number, call them and tell them what you want to know. Give them the serial #, and they may want to know the model also. They should be able to tell you what year it was made. Hope this helps. I will Actually see if I can find out the info for you. I will be right back. Sara I just talked to troy built, this is not the serial # this is a model number if you can check again for the complete serial# I can get you the year your tiller was made.
May 01, 2016 | Troy Garden
I have an old troy built junior tiller, the only numbers found as on the engine. 130202 0135-12 81100107 what year is this model? and were can i get a repair manual?
hello ,you can contact troy bilt at 1-800-269-6215 and check for your manual or go on line troy bilt.com tillers parts manual..add model number,
Feb 06, 2012 | Troy-Bilt Garden
I WAS JUST GIVEN A TROY BILT 5 HP REAR TINE PONY ROTA TILLER. THE DECAL WITH THE MODEL NUMBER ETC. ON THE TINE CASING IS UNREADABLE. DO YOU HAVE ANY IDEA WHAT MODEL THIS MIGHT BE? I WOULD LIKE TO GET A...
The serial # of the tiller should be stamped directly above the right wheel on the transmission housing. This should give you more info to work from.
May 02, 2011 | Troy-Bilt Pony Garden Tiller
I lost mt manual to my tiller. how do i get another manual?
If you have a Troy-bilt tiller, go to http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001 . Enter both your model number and serial number to access the manual online. If you want to order one, the price will probably be $10.
The model and serial number are likely on a plaque on the tine housing.
I hope this helps.
Mar 22, 2011 | Troy-Bilt Garden
I have an old troy bilt pony rotertiller no serial tag
ballping
Jul 26, 2010 | Troy-Bilt Pony Garden Tiller
How can I find a parts manual/breakdown for an older Troy Bilt tiller? I beleive it was manufactured in 1987 possible model #870487 definite S/N 87 46 39. This tiller has the 8 HP Kohler engine. I am...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in horse for your model number and you should be able to find a parts break down for your tiller. If the serial number is 874639 it was made in 3/88 and will be a four speed PTO model.
I find a lot of parts on Ebay for these tillers, your can order parts through MTD but they will be a little pricey. MTD aquired Troy Bilt out of bankruptcy in 2001 and still carries parts for the tillers.
Frank
Jun 27, 2010 | Troy-Bilt Garden
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Aug 03, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
26 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
