My unit isn't blowing cool air - Heating & Cooling
  • Heating & Co... Master
  • 1,929 Answers
Is the condenser outside running ? If so, is the larger sized copper cold?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Apr 16, 2017
Ac in my house not blowing air at all
check the drain for some type of float switch. possible the drain is backed up and the unit shut off on safety.
Dec 30, 2017 | Heating & Cooling
Ceramic heater only blow cool air
Unplug the unit and look on the bottom or the back, there may be a circuit breaker reset switch.
If not, it's probably a fuse that's blown inside the unit and isn't made to be replaced.
Sep 24, 2012 | Lasko 6405 Designer Series Osc. Ceramic...
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
Air conditioner isn't blowing cold air like it should
Hello, usually this can be caused by either a dirty filter, evaporator coil or low refrigerant charge.
May 22, 2012 | Goldstar Heating & Cooling
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
May 11, 2012 | Dehumidifiers
My A/C isn't blowiing cold air. the fan does work but it only blows air
Needs to be shot off, and cooled. Then it needs to be cleaned. Blow out unit with air compressor if have one, or a can of compressed air. Concentrating on coils, and filters. Point is, when they get dirty, or some time froze up, which is cause from being dirty, they can not breath and get proper air ventilation which cause motor to over work and then compressor will not cool. Use also shop van to really **** up anything air blew around that did not come out. Next step if this does not solve it, after plugging back in, then it is a leak in the freon, or charging of freon needs to be done. Thanks Mike
Sep 20, 2011 | Quasar HQ2101SH Air Conditioner
My A/C isn't blowing cold air. the fan does work but it just blows air
Here I am again, to make sure you got my answer again,
Needs to be shut off, and cooled down. Then it needs to be cleaned. Blow out unit with air compressor if have one, or a can of compressed air. Concentrating on coils, and filters. Point is, when they get dirty, or some time froze up, which is cause from being dirty, they can not breath and get proper air ventilation which cause motor to over work and then compressor will not cool. Use also shop van to really **** up anything air blew around that did not come out. Next step if this does not solve it, after plugging back in, then it is a leak in the freon, or charging of freon needs to be done. Thanks Mike
Sep 20, 2011 | Quasar HQ2121 Air Conditioner
I have 2 seperate Achiever AC-seer 10 units installed 6 yrs ago. One cools downstairs, the other upstairs. I have never used them before. They have been exposed to heavy snowstorms over the years in...
No Freon doesnt evaporate the only way you have to charge an A/C unit is if it has a leak somewhere in the system. It sounds like your compressor is locked up I would try installing a super boost to the Condenser (outside unit). Let me know
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Rudd air conditioner isn't cooling,blowing ,but isn't cooling my house because air is not cold
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Jun 19, 2011 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
