Question about Sewing Machines
How to thread a seammaster 200 - Sewing Machines
How do you thread an elnita 200 ?
How to thread and use Elna SU sewing machine
Athough most likely not your model, threading instructions are pretty much the same for the majority of machines except in extreme cases. Of course, a manual for your machine would also be helpful, even just for the maintenance and use instructions.
Elna Elnita 200
Elna 240
Instruction Manual Elna Elnita 200
Tip: ALWAYS RAISE the presser foot when threading the top thread. Always start out with a brand new needle (and change it at least every 8 hours of sewing time).
Dec 04, 2017 | Sewing Machines
Does my seammaster model 6950 do straight stiching or only zig zag?
Looking For Seammaster 6950 Users Manual Can You Help
If it looks like these photos, then it is capable of zig-zag and some other decorative stitches:
Vintage Seam Master Sewing Machine Model 6950 149 99
You also may want to talk to these guys about using the Simplicity manual for your machine:
http://www.sewingpartsonline.com/instruction-manual-simplicity-sl6950.aspx
Sep 18, 2017 | Sewing Machines
I have a Seammaster machine Model # 6950. I bought it with now book. How do I adjust the tension on the bobbin?
Here are some instructions regarding tension adjustment. However, before you try changing the bobbin tension, I suspect that it is the top thread creating the mess of thread. REMOVE the top thread from the machine, ALWAYS RAISE the presser foot, and rethread from the beginning.
Understanding Thread Tension Threads
There are some manuals available for purchase for your machine. Search for Simplicity Seammaster 6950.
Aug 04, 2017 | Sewing Machines
Hi I am having problem with my sewing machine. Thread gets all tangled up on the bottom of the fabric... My husband is very smart about machine and needs just suggestions from you.
That is called bird nesting or thread nesting and usually results from: mis-threading, thread not seated fully in the upper tension disk, or upper tension too loose. (Mis-threading may not be a user error--sometimes the thread will "jump" out of thread guide or the take-up lever.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low number and retest your machine. The upper tension will probably need some tweaking for your particular machine, but the mid-point is a good place to start.
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Tutorials Urban Threads Unique and Awesome Embroidery Designs
Jan 12, 2017 | Sewing Machines
Need a manual for seammaster sewing machine model sm1100
Search the internet for:
Manufacturer + Model + the word "Manual"
Jan 15, 2016 | Sewing Machines
Seammaster #6950. Where can I get a manual?
Dec 14, 2015 | Simplicity Sewing Machines
Need manual for seammaster sewing machine
Seammaster Sewing Machine manual - ManualsOnline.com
www.manualsonline.com/.../sewing.../seammaster-sewing-machine-manu...
Question About Simplicity Sewing Machine N71488649. Seammaster Sewing Machinemanual... Asked by Cassia Curtis on 10/26/2011 0 Answer.
Oct 07, 2012 | Sewing Machines
I have a necchi - singer - dressmaker ero-pro-seammaster serial #5854 model 6800 how do I find a book for this ?
I called my local library researcher and they found what I needed.
thanks so much
carla
Jan 29, 2010 | Necchi Sewing Machines
While sewing on singer quantum futura ce-200 sewing machine, thread bunchedup on underside of fabric and bobbin case flew out more than once.
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
Dec 27, 2008 | Singer CE-200 Quantum Futura Computerized...
Can't seem to embroider
brothers frame is much smaller I think 4 x 4. I have futura 200. found this to happen at first but now now. Make sure when threading that you floss the thread through the top part, it has plastic over it. The thread must fit properly in this part. (flossing means to run back and forth a couple of times holding thread tightly). Also, hold the 2 thread ends when you first start to embroider. Hope this helps
Apr 12, 2008 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
