Question about Electrical Supplies
My new onan 5500 generator on my fifth wheel is beeping after i turned it off. I cant find anything in the manual describing what this beeping indicates. Please help newbie rv owner!
SOURCE: Onan 4000 RV Generator - where is the oil drain plug?
It should have a cover on the floor bottom that is held in place with two torx (star) screws. remove the cover and you can remove the plug with a 9/16 socket.
Posted on Dec 02, 2008
  • 257 Answers
SOURCE: onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Posted on Mar 02, 2009
SOURCE: Have an Onan RV generator. WHat kind of oil do I
Standard 30W motor oil.
Posted on Apr 30, 2009
  • 26 Answers
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Posted on Aug 29, 2009
  • 5603 Answers
SOURCE: Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
Posted on Sep 05, 2009
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
Physical location of control board on an Onan 5500
It is right behind the start switch. There is one bolt that holds your start switch housing down, remove it and the housing. You will see the P1 connector with a lot of wires plugged into the control board
Dec 03, 2013 | Watts Onan Portable Generator - 4000 ,...
Onan 4 ky generator quits when a/c is turned on? Has no other load on it.
Is your generator 4 kW or 4000 Model 5500.
If 5500 as on the picture over your question the reason may be short in the receptacles or low voltage/ rpm.
If 4 kW MicroQuiet, there the reasons may be too much, that you will nead a troubleshooting manual.
Jun 14, 2010 | Watts Onan Portable Generator - 4000 ,...
My onan 6500 gen cranks slow and won't start new batterys and clean cables 12.5 v on one side of soleniod and 7.5 v on other
Your solenoid might be bad or your starter motor might need new carbon brushes. If you can take out the starter motor and see if you can manually rotate it, if it is not to hard to turn it, if hard to turn manually your starter might have something bad inside. A bad bearing or bushing. One more thing try this while cranking try to tap the starter motor.
Mar 15, 2010 | Watts Onan Portable Generator - 4000 ,...
I have an onan 5500 gas generator that wont start
What is the model? Chances are the carb needs cleaning or replaced.
Sep 21, 2009 | Watts Onan Portable Generator - 4000 ,...
RV Onan 4000 runs fine but not putting out enough voltage to run anything
Not sure how to set it up but you can take it and have the voltage turned up on your generator or the voltage regulator is out.
Sep 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
47 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
