Question about JVC Video Cameras
JVC gr da30u unit in safeguard mode can't get off
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
kala
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Posted on Feb 28, 2008
SOURCE: E01-E06 Unit in safeguard mode
I had this same problem, and indeed it was from leaving a tape in the camcorder while in storage. All I did was remove the tape and put a new one it. Solved my problem! Thank you!
Posted on Oct 16, 2008
mastertech48
  • 149 Answers
SOURCE: JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Posted on Sep 16, 2009
  • 4 Answers
SOURCE: Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Posted on Dec 17, 2009
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
How can I get a manual for my JVC camcorder,model#GR-DA30U. Also how do I get a USB for same camcorder?
JVC has manuals for the GR-DA30UC and GR-DA30US models at
http://books.jvc.com/booklist.asp?Model=GR-DA30U
Neither one of them has a USB port, so there are no USB cables for the camcorder
Oct 20, 2010 | Cameras
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I need jvc gr-da30u camcorder software for windows vista
iF IT IS NOT ON THE JVC WEB SITE, i MAY HAVE MY OLD CD. (Sorry Baby hit key) I will look in a bit. send me your email.
Dec 31, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
SAFEGUARD MODE ERROR CODE E06
Why not do what the manual says ? They're printed to assist you.
Jul 14, 2017 | JVC GR-D201U Mini DV Digital Camcorder
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
Safegaurd mode
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Video Cameras Logo
80 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
