Question about Refrigerators
Question about dual fans in console of EPIC EPEL09950 elliptical.
Both fans stopped operating. How to troubleshoot to determine if the fans or electronic board needs replaced? How to then find the needed replacement part numbers? Thanks.
  • Refrigerators Master
  • 10,045 Answers
Look on the back of the refrigerator for a pouch that contains the wiring diagram. If it isn't there, look behind the grille on the bottom front. Usually there troubleshooting instructions too. Parts can be gotten at any appliance parts store either near you or on line.
Posted on Apr 16, 2017
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews -
Jan 27, 2016 | Epic View 550 Treadmill
No resistance for Healthrider H90E elliptical
More than likely your going to need a console...If you checked all the power from the console down to the resistance motor and that's good then console is bad.
Dec 08, 2013 | HEALTHRIDER H90E Elliptical Console Model...
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Epic E 950
1= the resistance is adjusted magnetically.
2=the resistance is not adjusted o.k
3=check the bolts that secure the magnet
4=if there are slips, the resistance will slip,adjust
5= test the magnet, with the magnet withe the refrigerator. for attraction +resulpusion. and replace if do not pass the tests.,because they are de-magnetized.
God bless you
Jul 12, 2012 | Epic E 950 Elliptical Resistance...
A precor 5.21 elliptical exercise machine has died after a move. Display is dead and lift motor tries to go up past the breaking point. Disconnecting console stops lift motor execution. I need a...
According to your requirement contact visit and download the manual, it will help you to repair the machine. You can also visit Here the article may also help you. But first check the electric outlet and the electric input of the machine.
May 20, 2011 | Sport & Outdoor - Others
The one fan willl not come on but both will when motor is hot
I'm not familiar with your particular car, but this info may be of some help to you...
Dual fan cars work in a few ways:
1) Some only use one fan during normal cooling, and turn on the second either when the temperature reaches a certain level, and/or when the air conditioning is running.
2) Some use both fans for normal cooling, but at least one of the fans have a dual-speed motor. Generally only one has dual-speed motor, which operates at low speed during normal cooling cycles, and operates at high speed at a predetermined temperature, and/or when the air conditioning is running.
Based on this, it's possible that your system is working correctly, or you have the chance that your low speed portion of the cooling system is not functioning. Check the wires going to the fans. If there are only two wires, then it's a single speed fan. If there are three wires, it's a dual speed fan.
Based on that information, you should be able to determine if your system is working correctly or not.
Dec 13, 2009 | 1989 Honda Accord 4 Door
Plugged in a wrong adaptor and my elliptical started smoking
usually when you let the smoke out your done, but if it seems to be OK, I would just run (ellipe) with it. The board is probable damaged but working, you might of burned a few contacts, sniff around. You can take the covers off and look but if they are burned bad you might just finnish it off. How long it lasts can't be determined, but it is just a matter of time before it goes.
Mar 12, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
