HP LJ 9040- at first fuser that was orignally
HP LJ 9040- at first fuser that was orignally in the printer was not fusing toner to paper. change fuser same problem. I put orignal fuser back into printer and I notice envenlope tabs were up so I pushed them down and raised the fusing temp to high 2 which seem to solve that problem. However, I also notice a squeeking noise which I coming by the left door deliv assy. I'm not sure if its the top deliv assy or left door assy. can anyone help?
    Scholar:
  • 136 Answers
I take it your a tech or have tech ability
in my personal experience Squeeking or noticable squeeking has manily from the Output Assembly
if you can here it from the rear it is the Output assy. glad i could help
Posted on Jul 24, 2009
My HP LJ M602 had a jam. Paper is curled up between toner and fuser.It has a code of 13.B9.D1. Any ideas?
If removing the toner cartridge provides access, you can try removing the curled paper but you must work carefully to avoid leaving bits of paper stuck out of reach.
Apr 25, 2016 | HP Office Equipment & Supplies
Toner Not Sticking Well
There is a long bulb placed in the centre of the fuser roller below the pressure roller.
Check the halogen bulb INSIDE the fuser roller. Does it glow ?
Ensure the Voltage of the bulb matches your country.
Laserjet 5000 5100 fuser TPW LJ 5000 Assembly Diagram 810
Mar 26, 2016 | HP LaserJet 5000 Printer
What causes paper jam in hp 9040 laserjet copiers
IT all depends on the location of the paper jam. The usual causes are bad feed rollers and fuser units.
Mar 04, 2015 | HP LaserJet 9040n Printer
How do I solve this problem? My hp LJ 4345 printer experiences intermittent paper jam in fuser(accordion-like) with half of the paper out of the fuser. We've replaced the fuser with a new one but the
This error can be caused by the following:
1. Fuser that is close to end of life. Maximum print quantity is 225,000 pages.
2. poor quality paper, very thin paper never feeds well and will jam.
3. Printing an image that is almost entirely black can cause the paper to buckle before entering the fuser.
Try different paper to see if that resolves the problem.
Sep 02, 2014 | HP LaserJet 4345mfp Printer
Ink does not dry up
The printer doesn't use ink.
I'm thinking that your problem is that the toner is rubbing off the paper onto your hand.
You probably have a defective fuser.
In the grand scheme of things, the fuser gets hot and fuses (melts) the toner onto the paper.
Your fuser probably isn't getting hot enough to fuse the toner.
Get the fuser replaced.
Dec 31, 2010 | HP LaserJet 1100 Printer
Black toner flakes on paper
This could be a couple of things, easiest thing to try first is to put a different toner cartridge in, something that has already been opened because it would save you from opening a new one. Another thing you can try is sending a cleaning page through the printer to clean off excess toner from the fuser unit. What happens is over time toner builds up on the lower pressure roller of the fuser unit and after being heated and cooled so much the toner starts to flake off on your print outs. Follow these steps to try to clean the lower pressure roller:
To run the cleaning page manually
1.If a duplexer is installed, open the rear output bin.
2.Press check mark(SELECT button) or the MENU button to open the menus.
3.Use (UP ARROW button) or (DOWN ARROW button) to scroll to CONFIGURE DEVICE, and then press
4.Use or to scroll to PRINT QUALITY, and then press the check button
5.Use (UP ARROW button) or (DOWN ARROW button) to scroll to CREATE CLEANING PAGE for the(LJ 4200/4300) or PROCESS CLEANING PAGE if you printer is a(LJ 4250/4350) then press the check mark
6.Follow the instructions on the cleaning page to complete the cleaning process (LJ 4200/4300
only).
7.If a duplexer is installed, close the rear output bin.
This should help clear some of the flaking toner, if not you might have to replace the fuser unit.
Jul 31, 2009 | HP LaserJet 4300n Printer
Printing Problem
Image defects on LJ printers are usually the toner cart. or the fuser:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the image Defect on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 17, 2009 | HP LaserJet 4250n Printer
Problem in all print paper are lines & ... how to solve this problem
Print a test page
Hope this helps
Feb 20, 2009 | HP LaserJet P2015dn Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
I think the fuser is in your **** part. This problem can be corrected by sitting in a tub of salt water. Make sure the printer is plugged in and is powered on. Is the display lit? If it is place the printer in the tub of water you are sitting in. You sould now be able to realize nobody cares and it no longer matters
Oct 16, 2006 | HP Color LaserJet 3500 Printer
220 people viewed this question
k24674
jasbo
jasbo
