Question about Hayward Pool & Spa
My Hayward pool/spa heater won't ignite on pool heat setting but will on spa heat setting. We've had it for less than one year.
    Top Expert:
  • Hayward Master
  • 8,177 Answers
If all settings correct on controller bad display
Posted on Sep 05, 2017
rcampsr
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
SOURCE: Pool heater burners won't ignite.
Also you need to inspect the igniter.
Posted on Apr 25, 2009
  • 4 Answers
SOURCE: 1 year old hayward h1001d pool heater clicking
see this link ....
http://www.fixya.com/support/t1078177-hayward_pool_heater_h_series
Posted on May 25, 2009
  • 83 Answers
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Posted on Jul 01, 2009
  • 990 Answers
SOURCE: Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Posted on Dec 12, 2009
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
Apr 05, 2010 | Hayward H Series Pool & Spa Heater 400k...
Pool heater fires up and starts heating the water outflowing into the pool, but only stays warm for 5 minutes or less then cools and stops heating
You are tripping a temp limit switch. You either have a bad switch which you can jump the wire to confirm. This is a trouble shooting technic only. Jumping the wire permantly might cause bigger problems.
Aug 17, 2009 | Hayward H Series Propane Electronic...
I have a Hayward pool heater. It's about 5 years
would not suggest trying to manually light,its an electronic ign model so you may damage some wires with an open flame.try powering off then turning back on and see if display retuns to normal
Jun 19, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward h100id1 above ground pool heater has ignition failure. ignitor allumeur won't light (less than a year old"
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
Jun 08, 2009 | Hayward H Series Pool & Spa Heater 400k...
Heater ignites in spa mode but not pool mode . It worked fine last year but when I opened my pool this year I found it would not ignite in pool mode nor would the temperture control adjust. It does ignite...
Sounds like you may have a bad temperature sensor. Check for damaged wires or have a technician test the sensors. they should have a certain resistance property, if they are not within the set parameters the sensor will not allow the heater to fire. If there is a separate thermostat for the pool side, check that as well.
May 18, 2009 | Hayward H Series Millivolt 250,000 Btu...
Pool & Spa Logo
140 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
