Question about Soleus Dehumidifiers
Soleus hmt-d70e-a dehumidifier. I never here the fan kick off even when it reaches desired humidity level. Is this normal on this model.jake.
rick_stokes_
  • 61 Answers
SOURCE: My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Posted on Sep 16, 2009
  • 10865 Answers
SOURCE: Bought the 45 pint model yesterday. Seems to be
Hello. You will have to return this unit as it is faulty. J.
Posted on Jul 28, 2010
heatman101
  • 43501 Answers
SOURCE: My 40 pint Soleus dehumidifier doesn't pull any
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
  • 4736 Answers
SOURCE: just purchased a Danby dehumidifier
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 06, 2011
  • 4736 Answers
SOURCE: I have a DDR7009EE and the fan runs continuously
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Posted on Jul 28, 2011
How do I get my Danby dehumidifier, model#DDR70A2GP stop its fan from running continuously once it reaches a desired humidity level? Thanks
I just read your instruction manual for you, and it appears that you can't. You choose the humidity setting and you choose your fan speed and that's it. The machine will stop when the bucket is full.
Your manual is here;
http://www.danby.com/cms/documents/pdfs/en/DDR50A2GP_DDR60A2GP_DDR70A2GP_DDR60A1CP_EFOM_%28DM%29_Revised_Feb_27_2013_%28web2%29.pdf
Sep 12, 2015 | Danby Dehumidifiers
Cannot set humidity level to anything other than 50.
Is it reading the room humidity, rather than showing the set point? Check the manual.
Apr 21, 2012 | Soleus DP14503 Dehumidifier
Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Apr 16, 2012 | Haier HD456 Dehumidifier
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Jun 06, 2011 | Danby Dehumidifier
When the desired humidity level is reached (in my case 50 %), the unit does not go into standby - why is this? It reads 48% but is still running.
I would check the humidity sensor. I think it is located in the return side of that model. It may have trash on it.
Jun 04, 2011 | Danby DDR6009REE Dehumidifier
Hi, bought one two weeks ago. Try it on auto and set at 'normal', and 'dry' and the unit will stay running with out stopping over a period of day and a half. Collected about 1/3 tank of water. Phoned...
If you are in a very humid room or area it will not shut of until it reaches desired humidity% level that is set. If it is reaching the set level and not turning off I would return it.
Oct 06, 2009 | Whirlpool AD50USS Dehumidifier
Dehumidifiers Logo
150 people viewed this question
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
