Question about Vacuums
How to replace Terminal Cover on kenmor vacuum model116.27914
2 Suggested Answers
SOURCE: How to replace the Terminal Cover on top of the Extension Wand
I saw this in another FixYa post
it tells midway down how to get access to the wand fuse (which has the two-prong terminals)
Comment posted on Feb 09, 20082bubbles ok here we go.. fine a small file that will fit the holes at the bottom of the wand and break the file so that the flat end fit into the wand. please make sure the wand is not plug in to anything. now put it into the hole and try to clean it out gently not too hard or you will damage the contacts. after that grab a needle nose pilers and very gently press the contacts. not a lot or it won't fit back into the power-mate. ok now for the top of the wand. if you look at the wand where the button is to extent the wand. on each side you will see a small clip. with a small flat head screw driver push into the clip at the point closer to the wand tube. it will pop out. make sure to check the clip to see how to put it back in. after both clips are out you will notice a that the clips left a gap. the back part of the wand or cover will now slip off. push it toward the gap. then up. after removing the cover. you will see a ribbon strip which is attached to the prongs or fuse .you can remove the fuse and then clean the contacts. please be careful. once this is done you then put it all together and try it out. the fuse is a part that you can buy at sears if you have to. let me know if this helps you out. if it seems like too much just take it to sears and ask them to replace the wand fuse for you instead of replacing the whole wand. hope this helps .
Posted on Jan 08, 2009
Kenmore canisteer vacuum model 116 52513202 belt replace. I can't get the top cover off the powermate to replace the belt.
If you remove the headlight cover you will find two screws that need to be removed, than flip the power nozzle over and you will find a little catch on each side of the cover, if you pull or pry the cover out a little the cover can be removed from the nozzle housing.
Nov 25, 2016 | Kenmore Vacuums
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
Belt
You probably need a phillips screwdriver to Remove the screws on the bottom of the vacuum and pull the brush bar out _ the belt is wrapped around one end of that and anchored to the vacuum - put new belt on and replace cover on bottom by replacing the screws.
Jul 25, 2013 | Kenmore Vacuums
Power Head keeps cutting in and out while vacuuming???Canister motor keeps running but the power head starts and stops like there is a short or some loss of connection somewhere. Any ideas?
The electrical terminal at the top of the extension wand may be loose or corroded. Unplug the vacuum and remove the wand from the hose assembly. Look at the 2 prongs and clean off any corrosion using a a Q-tip or scrape with a screwdiver if it's more persistent. After cleaning reconnect the wand to the hose and try it again. If the prongs are not corroded, they might be loose instead or they might not be aligned properly. If this is the case then bending the prongs very slightly may help realign them. The part that may be giving you the trouble is called the terminal cover (PN 8191782). It costs about $10 but the problem is knowing the procedure to actually replace the part. CAN ANYONE EXPLAIN HOW TO OPEN UP THE EXTENSION WAND TO REPLACE THE TERMINAL COVER ??
Jan 14, 2010 | Kenmore 23913 Progressive PowerMate Bagged...
How do I replace the belt on my Kenmore canister vacuum?
Turn the power brush over so the bottom faces up. On the bottom there are two access screws. Remove the two screws and then the top cover can be removed from the base. With the top cover off you can access the belt. You can get a replacement belt for your model here:
Kenmore Progressive Replacement Belt
Nov 17, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
How to open a kenmore powermate vacuum to replace belt
You have to take the light cover off (push in at the bottom on each side) and there are two screws.
Some models have pressure locks on the back of the power nozzel cover. Just use a screw driver.
Jul 15, 2009 | Kenmore Canister Vacuum Vacuum
Kenmore Progressive Vacuum-Need to replace plug
Splice a new plug, but get a good one. Tough with a scew to hold it together
  • White wire goes on the silver terminal.
  • Black wire goes on the gold terminal.
  • Green (or bare ground) wire goes on the green terminal
More here:http://www.hammerzone.com/archives/elect/accessories/ext_cord/end1/replace.htm
Mar 26, 2009 | Kenmore 25812 / 25813 Progressive Bagged...
The back filter and cover blow off immed when vacuum turnd on
Has the cover got tabs that is suppose to catch when it's installed? check and see if there are broken plastic ends either on the vac or cover. It should be able to catch to hold it on.
Jan 31, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Dec 20, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
