Question about AO Smith Pool & Spa
How to covert a 220 motor to a 115vac motor. ao smith rpm3450 3.hp 15 amps
    Diehard:
    Visited the website for 60 consecutive days.
  • 121 Answers
If your label looks like this one and or if your label dose not have 120 as one of the voltages then you can not run the motor on 115 volts.
how to covert a 220 motor to a 115vac motor. ao sm - century-sq1302v1-2-yrzb4gnga4otx0okltvk2h2e-3-0.jpg
Posted on Apr 17, 2017
    Top Expert:
  • AO Smith Master
  • 12,962 Answers
When you wire the motor just use one of the 115 volt lines and ground. Tape up the other connection to prevent it from contacting anything else. Motor will spin at lower speed with less power but will work on 115 volts.
Posted on Apr 16, 2017
My new AO Smith motor ran for 15 mins amnd overjeated, Is it wired wrong?
check voltage and see side of motor if wired 220 volt wiring should be good if 120 volt have to move brown and white wires
Jun 08, 2014 | Smith AO Pool Pump Motor
New motor and it overheated afterr 15 mins and shut off
make sure on side of motor is wired for 220 volt 1 hot to L1 2nd hot to L2 green to ground
Need wiring diagram for AO Smith Motor. Model # K48K2PA105. Label gone. Not sure if its ready for 120 or 240. Any help appreciated
Remove the rear cover and take a look. Unless this is a very old motor, there will be an indicator on the tab that will tell you the information you seek.
Normally ... let me say again, normally, a larger motor will come default 220 while a fractional hp motor will be 110.
To be double sure, take your motor to your Professional Pool shop and ask them to have a look.
Jul 29, 2011 | AO Smith SQ1152 Pool Pump Motor
C/l pump 1hp. hook up is a 220 orage cover wire ment for 220 wired &coverted to 110 at breaker pannel with out door receptial gounded on end. pump pluged into it put plug breaker at plug in keeps...
A motor set up for 230VAC will run on 115VAC but will overheat and shut down over time. The motor nameplate should tell you what wires need to be reconnected and how in order to operate the motor on a 115VAC circuit. Once you change the wires your motor should go back to normal operation.
John
Oct 26, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Pool pump turns off after 1/2 hour or so but I can turn on manually after it sits for a while. Timer is working fine. Hayward Super II around 5 yrs old. Do I need to replace this motor? This problem just...
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Pool & Spa Logo
32 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
