Question about Exercise & Fitness
I moved the seat carriage all the way forward and now the locking arm seems stuck and I cannot move the seat carriage back to a decent position. How can I fix this?
This is for a Fitness Quest Edge 491 recumbent bicycle.
emissionwiz
  • 77499 Answers
SOURCE: power seat control broken
I am sorry but there is no way to operate the seat without power function working unless you take the whole thing apart.
Posted on Sep 09, 2008
SOURCE: Driver's seat unable to move forward or backward
There are plastic gears connecting the track to the seat assembly. Whne one of these strip the seat will only work or move to one side. Infiniti does not sell a simple fix. You are looking at buying an entire seat assembly complete with the module for all the electronics. It will be at a cost of around $950 - $1000. Once that is in, Infiniti must program the seat to the brain of the car, only then can you reset your memory settings.
Posted on Oct 02, 2009
SOURCE: Electric front seat stuck in forward position.
I had the same problem on my 2003 Toyota Camry. The threaded drive screws are what spin underneath the seat and cause the seat to move back and forth (same way a garage door opens or closes). When the seat gets all the way in the forward position, the threading on the drive screws ends, which causes the bolts connected to the seat to jam and get stuck. It should sound like the motor is trying to turn but it won't, it just clicks. Un-jam the bolts and rotate them one rotation from the all the way forward position to ensure your seat is reinstalled straight.
Posted on Oct 28, 2009
SOURCE: I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
Posted on Feb 28, 2010
  • 63 Answers
SOURCE: power seat control not working to move seat back.
that is easy find the motor under the seat that moves the seat back and forth take and neg wire and a hot wire carefully touch the twoo prongs going to the motor after diconnecting the plug going into the motor. it sould go forward one way and croos the wires to get it to go the other way if this works get a new switch and have a working seat.
Posted on Jul 01, 2010
Driver's side power seat won't move back but will move forward, up and down
If this is a 1994+ Ford, it might be that the seat belt latch is the problem. Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
Sep 09, 2013 | Computers & Internet
Electric seat stuck in up position
under your seat you 2 motors 1 for up and down and the other for back and forward check the motor for the one not wroking
Sep 24, 2012 | 2008 Nissan X-Trail
1990 Park Ave drivers seat recliner motor
You must remove the motor, move the seat to the desired position and then reinstall the motor to lock the seat in the position.
Sep 10, 2012 | Cars & Trucks
Seat Position Cant be moved
The manual lever to release the seat is supposed to have a spring on it to return the release lever to the lock position, if the lever does not spring back when you let go of the seat adjustment lever then you know there is a missing, dis-connected, or broken return spring.
If this is the case try putting the seat where you want it to be and make sure that the adjustment lever returns to the lock position, now check to see if the seat will lock in with the adjustment lever in the lock position.
If it does lock in repair or replace the return spring.
Make sure that the adjustment lever is attached to the locking linkage and it does move the locking mechanism.
If it still does not lock into place then there is something wrong with the seat locking mechanism, and some WD-40 sprayed onto the seat rails and track might release a stuck mechanism, and if everything seems to be working alright, and you can see that the locking mechanism in the seat rail is moving in and out of the lock position, then the locking tabs are most likely sheered off and you will need to replace the seat.
Also look under the drivers side seat and compare the lever position and the linkage connections with the passenger side seat, and make sure that it is all operating like the drivers side seat.
Apr 28, 2010 | 2000 Renault Sportwagon
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Jun 02, 2009 | 2004 GMC Envoy
System error L1-00
the L1-00 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
If it seems to be moving freely for a bit and then stop - is it going back to its "home" position (starting point). Remove the main glass and then move the scan carriage by hand (with the copier turned off) .. does the carriage move ok? check for a loose carriage drive wire or debris or something broken. Make sure the carriage locking screw is not holding it. Then turn the copier back on and see if the carriage makes an attempt to move back to its starting point. if everything seems to be moving ok then the problem could ly with the "home position" sensor. It could also possibly be a bad drive motor.
Apr 03, 2009 | Sharp AL-1655CS Copier
Blinking with L and 1 alternately
the L and 1 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
Apr 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
1999 volvo s80 passenger seat stuck in forward position
you will need to check to make sure no coins fell into the track and is jammed it if not you will need to replace the bottom frame of the seat possible with a junk yard one much cheaper than buying new and junkyard frames come complete.
Nov 16, 2008 | 1999 Volvo S80
Front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
Jul 22, 2008 | 2000 Ford Focus
Exercise & Fitness Logo
27 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
