Question about Jensen Car Audio & Video
How to get the navigation to work on the Jensen uv9
SOURCE: Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Posted on Apr 15, 2009
  • 909 Answers
SOURCE: I bought a Phase Linear uv9 and it say the front
It's a very common cable, there are many on e-bay under computer-accesories-cables. Also available at local PC shop.
Posted on Jun 03, 2009
  • 4 Answers
SOURCE: how do u bypass the parking brake switch on the
Go to this link and problem solved
Posted on Jun 18, 2009
  • 69 Answers
SOURCE: I need the code to disable to parking break to
you will need the remote control to do so.
1.turn the radio on and select the setup menu.
2. while in the setup menu, use the remote and press 5-4-3-2-1-0, this should access another service menu.
3. from there, you will see a brake override option.
4. and your done.. hope this helps
Posted on Aug 17, 2009
Testimonial: "worked like a charm. thanks much for the help!"
drifterK
  • 4924 Answers
SOURCE: the jensen uv9 will play
If it used to work ...it may have an odd setting made and the easiest way to make it work is to reset it ...take a look in the left side near the volume button it has a reset one...it may be a hole it which you will have to insert a needle or a pen ...and keep t pressed for a few seconds...This will reset all setting to the factory default..
Also you should clean the laser head if it still makes trouble after this operation ..
Posted on Dec 25, 2010
I need the color coded wiring diagram for a linear uv9 rear plug
  • If you have any comments feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 15, 2011 | Car Audio & Video
I have a jensen uv9 and don't want to show the dvd even cd he said no disc
dirty eye on disc player you need disc cleaner then try it out.
Mar 09, 2011 | Car Audio & Video
How do i hook up a ipod to the stereo?
You will need to use the Media link provided with deck (it should have come in box) If you had purchased the deck form a private seller you can find it on ebay here are the links for the media link and the ipod attachment cable...
Media Link http://cgi.ebay.com/JENSEN-MEDIALINK-4-iPOD-INPUT-VM9512HD-VM9312-VM9312HD-/230561415259?pt=LH_DefaultDomain_0&hash=item35ae88005b#ht_2062wt_905
Ipod Sync cable for Media Link http://cgi.ebay.com/iPOD-iPHONE-CABLE-MSR3007-MSR2007-VM9312-VM9312HD-UV9-/190448728210?pt=Car_Audio_In_Dash_Receivers&hash=item2c57a0f892#ht_2628wt_1139
Jan 08, 2011 | Jensen VM9312HD Car DVD Player
Jensen uv9. played half the cd for a while then a week later just started to say bad disc for every cd, even new ones
you need a new cd player because the laser assembly has messed up or you can take it to get it repaired but will cost more than a new cd player
Sep 21, 2009 | Jensen Car Audio & Video
Why is the uv9 telling me usb not supported
the audio format may not be supported...if the files are supported than it might be the file protecting switch (dont know exactly what its called.) if not then i apologize thats passed me...
Aug 30, 2009 | Jensen VM9020TS Car DVD Player
I need the code to disable to parking break to watch my dvd's while driving with my jensen phase linear uv9
Aug 17, 2009 | Phase Linear Car Audio & Video
Jensen UV9 wont hold preset stations
the memory wire will be the thick yellow wire that is your constant. you hook the yellow wire to the yellow wire on the radio and you should be good.
Jul 22, 2009 | Car Audio & Video
Jun 03, 2009 | Car Audio & Video
Nov 12, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
