Why do I have a black screen with lights flashing then a steady red lamp light on? Model 50V500 with stand serial V4H032395
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
  • 3 Answers
SOURCE: stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Posted on Jun 06, 2009
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
bulbguy
  • 37 Answers
SOURCE: Red power light and buzzing sound with red lamp light.
If the lamp does not light at all, it is probably a bad lamp. The buzzing may be the ballast trying to start the lamp or a problem with the power supply. Check the lamp and see if the arc tube is broken. If its a new lamp, you should be under warranty. I have the manual if you want to go to me site at allprojectorlamps.com. Just send you email to me attention Bulb Guy
Posted on Aug 17, 2010
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
Apr 14, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Color is red to yellow. New bulb put in
A LAMP will not cause this problem. Do you have a reddish oval in the middle of the screen on a black and white program?
This model is prone to bad optical light engines (50V500) and there are several class action lawsuits pending right now.
Any discoloration usually means a burnt light engine--give me a better idea what the screen looks like and I will assist you for free.
If my input has helped you know what is wrong rate this solution as "very helpful" as I do this here for free.
Comment on this and I will answer your questions--I am here to help you.
SD TECH
Aug 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
I have hitachi 50v500 my screen went black and the lamp light comes on by the power button
Lamp light ON means TV needs new lamp as existing lamp is either broken or dead.
Replace lamp in TV, replacement procedure would be written in user manual.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
We have a 50V500 Hitachi Ultravision TV, temp and lamp light started flashing and then the lamp light stays on steady, now TV will not come on.
Howdy,
You need to replace the lamp; UX21511 about $100.00 for a replacement. It is very easy to replace.
Good Luck, big IRISH.
Dec 28, 2009 | Televison & Video
The red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Jul 14, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Replacement Lamp Hitachi 50V500
It must be a red light flashing as the 50V500 has no green lights on it. Make sure that when you place the lamp cover back on that it is activting the micro switch behind it. Otherwise the set will assume the door is open and won't ignite the lamp. Otherwise the ballast could be the issue.
Feb 02, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
