Question about Furniture
2 year old cooler will no longer cool Front panel says E1. What does that mean?
docjohn174
  • 943 Answers
SOURCE: not cooling
thanks for the question no not a job for you you need gages and knowledge of operating presures let a service tech do this thanks the appliance doc
Posted on Sep 16, 2008
e-Guru
  • 3917 Answers
SOURCE: Water Cooler Not cool
hi,
Please check the control.
Posted on May 06, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
  • 2427 Answers
SOURCE: Baumatic BW18 wine cooler; at
the soft humming your hearing could possibly be the compressor stalling.. this can come from a lack or freon. Now this is the first thing you should check as its one of the most common issues in all refrigerant systems.. to do this there is a check port that you connect a guage too and it will give the freon pressure. More than likely you will find it very low and needs re gassing.. before having it regassed I'd suggest that you have it checked for leaks as well ,, (it ran out of freon rather quickly no ??) have a technician come in and check these as he will have all the right tools and stuff needed for for the checking of gas pressure, the dye to check for leaks as well as the freon to regas it.. and if needed the solder to fix any leaks..
Posted on Sep 17, 2010
SOURCE: i have a 2 year old whirlpool water cooler that no
I hope this doesn't sound insulting, but there is a switch in the back that controls uniquely the hot water, is it set to on?
Posted on Jan 30, 2011
Cololer humms loudly and no longer really cools much. Room temp 80 and contents of cooler at 70 though cooler is set to 55°. It is about 11 years old. Is it just worn out and a walk away?
In reality it probably just needs refrigerant gas, but worst case scenario is that the compressor is failing. If it is in reasonable condition inside and out, you can get it fixed for gas, but would be uneconomical to replace the compressor. If not, newer ones are more efficient and cost less to run.
Dec 13, 2017 | Heating & Cooling
Igloo wine cooler FRW823 error code e1
E1 error code on display panel and
audible alarm sounding six times every
minute (Compressor fault - high/low
amps).
Items to check:
All of the below is in the back of the unit near the compressor.
Compressor wires disconnected.
Check wiring diagram on back of unit
and reconnect wires.
Faulty compressor.
Faulty control.
Faulty compressor overload.
Faulty compressor PTC starter.
Nov 19, 2017 | Furniture
Good day ! I have a Koolatron WC12 cooler that stopped cooling ,the fan works !It is not even a year old ?
1-800-265-8456 phone # for parts/service
Koolatron
U.S.A.
433 0 Commerce Dr.
Bata via, NY 14020-4102 U.S.A.
It is out of warranty if more than a year old.
I can find no service manual. There is a generic video: http://www.newair.com/kb/repair-cooling-kit-wine-cooler/
Replacement parts were sold at Truck Stops. That said, coolers are not known for their longevity. Source: http://www.truck-drivers-money-saving-tips.com/thermoelectric-cooler.html
What to Do When your Wine Cooler Wont Cool
Jun 10, 2017 | Koolatron Refrigerators
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Unit gets very hot within 5 minutes and slows graphics down to a crawl or crashes the machine.
I solved a really familiar problem 2 days before here at home.
The problem is, that your notebook gets really hot within minutes. As it gets to an exact temperature, the CPU first slos down, then shuts down, to prevent damage, and to cool down. If it's an "old" notebook (I mean at least 1,5 - 2 years old), then the thermal paste on the processor got dry, and it doesn't do its job anymore. You have to apply a new amount of thermal paste (BTW you really should do it at least once a year).
1. Turn the notebook upside down
2. Take out the screws from the biggest panel (must be next to the heat grille)
3. Take out the screws from the cooler of the CPU
4. There will be a lot of white stuff on the CPU, clean it VERY carefully (tissue with alcohol, but NOT brush)
5. Apply a little thermal paste on the CPU
6. Take the CPU cooler back, and take the screws back
7. Take the bottom panel bake, and take the screws back
Here is a tutorial of it: http://www.youtube.com/watch?v=g3Izxh7J44s
The other solution is to buy a notebook cooler: http://www.notebookcooler.info/media/ante-notebook-cooler-s.jpg
Hope I could help.
Dec 29, 2010 | Dell Latitude D620 Notebook
The top display says F2:E1 and the oven won't function. How do I fix this?
This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
Nov 04, 2010 | KitchenAid Architect Series KEMC308KSS...
Doesn't cool and i am assuming that means the condensor. How much to fix. it is two years old but with very little use , looks brand new.
clean coils front and back....clean drain oil fan motor...take cover off relay...clean plugs and pins( from oxide)...if it starts hard get a har d start kit for compressor
Aug 28, 2009 | Danby Silhouette DWC512BL Wine Cooler
No longer cools.
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Mar 08, 2009 | Avanti WC494D Compact Wine Cooler Beverage...
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
