Question about Vermeer V1150 Trencher
Trencher clutch lever - Vermeer V1150 Trencher
    Top Expert:
  • Vermeer Master
  • 6,233 Answers
Best Manuals Guess you should try one of these ebooks. It's very helpful, I use it too
Posted on Nov 09, 2017
Boom on ditch trencher wont move up or down after hydraulic hose was replaced. how do you bleed air from system ?
Loosen the fitting at the hydraulic cylinder, start unit loosen fitting bleed till no air comes out.
Jul 18, 2016 | Vermeer V1150 Trencher
How do I adjust the trencher chain. It's loose. I would think there is a grease fitting, but can't find it.
trencher chains run fairly loose as tight chains break when the teeth hit rock as for a grease nipple , there is probably not one as it would break off while digging
Feb 18, 2016 | Garden
My bike was running perfectly fine, until I changed the clutch lever. I got an after market shorty lever, and installed it just as the oem one. Now it will crank, but not shift without dying...?
Hi, Matt my thoughts are the shorty lever pull distance may not be the same as your Oem lever and is confusing your clutch safety switch/sensor for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Installed new clutch lever Now Clutch will not engage
New clutch bike stalls when put in 1st PLS HELP 05 R6
http://www.apriliaforum.com/forums/showthread.php?253387-Help!-Installed-New-Levers-and-Clutch-Won-t-Disengage
Installed new clutch lever now no start
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 30, 2015 | Motorcycles
Trying to find parts manual or parts
Find the serial number and model number. Give Vemeer a call and they will be able to give you the part numbers. Probably give you a schematic as well.
Jul 15, 2014 | Vermeer V1150 Trencher
I have a broken clutch bearing and icant find the spare
  1. Clutch Lever
    • As the clutch lever is operated over time, it gradually loses its grip on the clutch cable, weakening the clutch lever action until it barely moves the clutch plates. Maintain the clutch lever by ensuring the free play at the lever meets the specifications of the motorcycle's user manual, in which you will also find instructions on how to make this adjustment.
    Clutch Cable
    • Unlike the gradual onset of a clutch lever problem, the somewhat uncommon failure of a clutch cable is instantaneous. With little warning, the clutch lever goes completely slack and the clutch will be inoperable. Keeping a clutch cable well lubricated can prevent failure. However, in the event of a cable failure, a registered dealer should fit a replacement.
    Clutch Plates
    • Problems with the clutch mechanism itself normally manifest themselves in the gear change rather than in the applying and releasing of the clutch lever. Noise, chattering or slipping can be the result of misaligned or warped plates, leaks in hydraulic cables or bearings. Although more serious, if recognized early, these problems will be relatively inexpensive to repair.
Jan 15, 2013 | 1975 Moto Guzzi 850 T 3
Why does my 2005 Chevy trailblazer make chirping noise in morning coming from my engine
it can be a number of things ac clutch idler pulley trencher alternator power steering water pump and belt most likely is an old belt because its stiff and slips when cold it warms up the belt is more flexible and it grabs beater the trencher can be weak and with the cold belt it can slip
Jan 11, 2013 | 2005 Chevrolet Trailblazer Ext
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
Aug 08, 2009 | 2001 Ford Mustang
Vermeer V1150 Trencher Logo
518 people viewed this question
Top Vermeer Heavy Machinery Experts
Tony Crow
john h
Tom Chichester
Are you a Vermeer Heavy Machinery Expert? Answer questions, earn points and help others
