Question about Black Computers & Internet
Up 6735s laptop starts but screen stays black
4 Suggested Answers
  • 21 Answers
SOURCE: The hp 6735s laptop wont start up?
At this point it sounds like your version of Windows is corrupt.
Try these steps
  1. Turn on your computer
  2. Count to 3
  3. Hold down the SHIFT or F8 key on your keyboard
  4. From the menu that appears look for the option marked "Safemode" enter the number on your keyboard that is beside safemode and press enter
  5. When windows loads click Start and choose Run
  6. in run type in "sfc /scannow" without quotes and press OK
  7. You may be prompted for your Windows CD. If you are, put your Windows CD or System Recovery Disk in your CD ROM and press okay
  8. This process can take a while. Once its done, reboot...
If the same screen that you described comes up again you may need to reinstall Windows.. This is done by putting your Windows CD or System Recovery CD in the CD ROM drive and rebooting your computer.
Hope this helps! If it doesn't please post back and I'll provide more help
Posted on Aug 17, 2009
Testimonial: "Thank you - Hard Drive knackered - HP sending new one out - cheers for your help!"
  • 57 Answers
SOURCE: my acer 5735 laptop sreen stays black at start up
First of all, go to advanced boot options, and see whether last known good configuration works or not
can you boot into safe mode? If so, try to do system restore, if that doesn't work as well, try to do a clean boot, followed by an advanced clean boot and a hardware clean boot.. these steps might help ..
clean boot :
advanced clean boot :
hardware clean boot :
Follow the steps below to perform hardware clean boot
1. Right click on My Computer -> Properties
2. Hardware Tab -> Device Manager
3. Right Click on Sound Card, Video Adapter, Network Adapter one by one and click disable
4. Reboot the computer. If the problem is fixed then you can enable the hardware devices one by one to find the exact device that cause the problem
If these steps don't solve the problem, unplug any external devices from your computer and see whether that resolves the problem .
If nothing works, try doing system restore from winre, if that doesn't work as well, you'd have to do that manually,
try these steps,
go to WinRE) open folder C:\Windows\System32\config
and rename these files:
(don't change COMPONENTS file because system don't store any copy of this file,BCD-Template system will reconstruct automatically when you boot into WinRE)
Next navigate to C:\Windows\System32\config\RegBack folder and copy all items to C:\Windows\System32\config
Next boot into WinRE and try again restore system to previous checkpoint.
The last option would be to format your root drive and install the OS again..
Hope that helps, and good luck
Posted on Nov 23, 2009
  • 5660 Answers
SOURCE: my laptop is hp compaq
1) First check the Display to make sure this isn't the problem.
Laptop on shine a flashlight at the LCD screen, and various angles.
Do you see faint images?
Do you have a VGA monitor available? (Also referred to as a CRT. Resembles a small TV)
If so, laptop off plug the VGA monitor into the VGA connector on the Left side of the laptop.
(Typical VGA connector, )
Turn the VGA monitor on, and let it power up. Once the VGA monitor is powered up turn the laptop on.
Is there a display on the VGA monitor?
If not press and hold down on the Fn key, then tap the F4 key.
This action should toggle your display over to an external monitor.
Yes? You have a display on the external (VGA) monitor?
Then you have a problem with the Backlight, or the Inverter.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is used as an additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Typical size is 3 to 5 inches long, and half the diameter of a No.2 pencil.
A Backlight is located within the metal framework holding the LCD layers together, and is on one edge of those layers. {An LCD screen is composed of layers)
An Inverter is used to provide power from the laptop for the LCD screen, and the Backlight.
90 percent of the time the problem is the Inverter.
An Inverter is a small circuit board located within the Display Assembly. Behind the Bezel of the Display Assembly, and located usually at the bottom of the LCD screen.
(The Bezel is the thin plastic frame that surrounds the LCD screen in the front)
Typical example of an Inverter for an HP Compaq 6735S,
The Display Assembly needs to be removed from the laptop, in order to remove the Bezel, and gain access to the Inverter.
Pictorial guide of how to remove the Display Assembly,
Follow Steps 1 through 7.
This pictorial guide shows how to remove the Bezel. The guide is for replacing a webcam module.
Disregard removing the webcam module, and follow the other steps.
2) If NO display is shown on the external monitor you have a graphic chipset problem.
This requires replacement of the motherboard.
Chip and Chipset are slang terms to mean I.C.
Integrated Circuit.
The graphics chip is mounted to the motherboard with a BGA surface mount. (Ball Grid Array)
Having the chip removed and replaced is more expensive than replacing the motherboard.
This is the download page for the Service Manual (Free) from HP Support,
Under the heading > Service and maintenance information, click on the file name,
HP Compaq 6730S and 6735S Notebook PC - Maintenance and Service Guide.
This is a PDF file.
Usually takes 2 to 5 seconds to see the first page come up, and additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
Posted on Dec 04, 2010
Hp 6735s GW694AV flashing caps lock light 3 times, and wont start-up, screen stays blank
Try Hp support center entering the model number remember HP in front. If no answer found there try replacing memory chip(s) Was there a problem with it keeping time just before it stopped working? Try replacing battery.
Dec 17, 2014 | HP Computers & Internet
HP 6735s will not boot.
Remove the battery, place the laptop in a warm, dry and sunny spot for several days so it dries out completely. Replace the battery and see if the laptop boots up.
If not then the laptop maybe beyond repair, especially when water was spilt on the laptop when it was running. This could have caused some electronic components to short out.
Feb 26, 2012 | HP Compaq 6735s Notebook PC
Hi. I have hp 6735s laptop and when I move him screen suddenly go black or in rare case white and I need to hold power button to shut down and when I turn him on everything is normal until I move him again...
When you say you move him, do you mean lifting the unit and moving to another location or just moving the lid (changing angle of the lid/lcd)?
If changing the angle of the display gives you black/white screen, you may be having problem with the LCD cable, it might be loose or defective. But if moving the unit to another location gives you the black/white screen, one component of the unit might be loose. Either you need to properly reinsert the memory of the harddrive. If these simple steps will not resolve the issue then you might need to check the whole motherboard including the connection to the LCD.
Hope this helps.
May 19, 2011 | HP Compaq 6735s Notebook
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
HP 6735s screen black out on startup.
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Feb 28, 2010 | HP 6735s Notebook Laptops
HP 6735s laptop with AMD Turion X2, screen remain dark...
Try locating your memory sticks under unit, try taking them out and resitting them, try also resitting your hard drive.
if this does not work let us know
Jan 04, 2010 | HP Compaq 6735s Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hp 6735s screen blank problem
If you use it from the power cable does it work better? There is a known issue with the 6735s and power management settings from battery.
Oct 02, 2009 | HP Compaq 6735s Notebook
Computers & Internet Logo
51 people viewed this question
Top Black Computers & Internet Experts
Are you a Black Computer and Internet Expert? Answer questions, earn points and help others
