Question about Kenwood Car Audio & Video
Kenwood KR920-Turned on unit,FM tuner worked for about 15 minutes and just quits working. AM tuner and everything else seems to work fine. Any suggestions on what could be the issue with the FM tuner?
hardrocko
  • 1476 Answers
SOURCE: My Emerson NR305TT will not produce sound
You have one of 3 problems:1) bad solder joints in the amplifier or preamp section 2)defective output transistors/ICs in the power amp or 3)missing or incorrect voltages to the amp section. If the unit has a headphone jack plug in a headset. If you have sound then everything is OK thru the preamp section and your problem is in the power amp. Any competent repair shop should be able to solve this one easily.
Posted on Jun 23, 2006
SOURCE: YST-MSW10 quits after about 15 minutes
As far as I can tell, this unit does not have a breaker or anything that would "trip" and be reset by powering off and on. It does have a fuse, which can blow (I replaced mine once) but if the fuse blows, you'll get no power until the fuse is replaced. Spidi, is your computer connected to your subwoofer's line 1 in connection or line 2 in connection? If line 2, that would explain the problem because the auto-off circuit only monitors line 1 in. If there is no signal on the line 1 input, it will power off every 15 minutes. If you are connected via line 1 in, the subwoofer should stay on as long as the volume is fairly loud. That's my problem. At low volume levels, the unit will auto-off even though I'm hearing plenty of bass through the sub. Drives me nuts, but I haven't found a way to disable the auto-off feature. Schematics anyone?
Posted on Nov 07, 2007
  • 1027 Answers
SOURCE: Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card problems
Have you checked the installation? - most PCI capture cards use the audio card of the PC for sound. A jumper cord is needed to come out the capture card and into the audio line-in jack. Green jack on the capture card is OUT, and the Blue jack on the sound card is Line IN.
Posted on Jun 18, 2008
نطلب منكم السماح رفع deriver saa7130hl
Posted on Dec 05, 2008
MY SAA7130 TV TUNER CARD IS NOT OUTPUT NORMAL CA LOUR IT SO ONLY BLACK AND WHITE CA LOUR ONLY PLZ SOLVE MY PRB.
Posted on Aug 31, 2009
Yamaha YST-C11 FM Tuner Not Working
i am at school and i whant to get on facebook
Feb 09, 2010 | Audio Players & Recorders
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Comunicating between different models, can it be done?
sometime your program is wrong... so plz go this website and u can get soft the prob :)
this website have sofware :) so nice man!
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Jun 13, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
KENWOOD KRC-2007 CAR AUDIO CASSETTE RECEIVER
It seems the problem is the fm tuner pack.
You can get it from pacparts.com
Part number is W02-1576-08
Jan 17, 2008 | Kenwood KRC-2007 Cassette Player
Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Mar 23, 2007 | Kenwood KDC-MP228 CD Player
Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Mar 01, 2007 | Technics ST-GT350 Tuner
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
