Question about Royal Office Equipment & Supplies
Royal 583cx, paper end show up when ever i plug the power cord in. Not going off even when i put the key on the off position and all keys are not fuctuning
  • 3 Answers
SOURCE: alarm
The 'mazda' setting is supposed to look like an analog clock, and that's for setting the time. The key position puts the clock in operating mode, as opposed to clock set or alarm set modes.
I've only had the clock for a day, but if you want the alarms to shut off and alarm again the next day, use the OFF switch on the top right of the unit. If you want to disable the alarms completely, use the 1 and 2 buttons behind the OFF switch to cycle each alarm through the settings: none, bell, music (radio)
Posted on Nov 16, 2007
  • 1263 Answers
SOURCE: 2002 oldmobile bravada ignition key is stuck in lock position
try and turn your steering wheel a little bit left or right and and the same time try and turn the key when it turns toward the dash then try and turn the key back. try and repeat this several times if neccessary. this should work. please rate this solution. thanks
Posted on Aug 30, 2008
  • 311 Answers
SOURCE: ram will not reverse at end of cycle
ive been a repairman for 17 years but havent had to fix a lot of these because ther not out there,but have done drives on a worm gear and i suspect that theres some wear there and its jumping the gear and thats where your getting the poping noise.their not the funest but you,ll have to take apart and opperate and watch/inspect.hope that helps God bless
Posted on Jan 04, 2009
  • 1187 Answers
SOURCE: could someone please tell me where can i buy
OfficeMax and Office Depot may have them.
Storemont (online) has the Royal Alpha 601 ($6.49):
Posted on Sep 22, 2009
  • 4070 Answers
SOURCE: engine immobilizer / theft deterrent
Hi! As a first course of action I strongly suggest that you open the hood and remove the positive battery connector then let it sit for atleast 5mins. to reset the car's system. After 5mins. reconnect the battery connector, turn the engine on and see how it goes. Hope this helps and thank you for using FixYa!
Posted on Nov 03, 2010
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
Royal star no electrical power
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Re No electrical power Road Star Forum Yamaha Road Star
OEM parts for Yamaha
May 28, 2012 | 1997 Yamaha Royal Star XVZ 1300 A
Royal 482cx cash register constantly running the reciept motor.
Tom, we have the same problem, did you get it fixed? Thanks,
Robinson Sew and Vac
Robinson IL
Jul 09, 2010 | Royal ALPHA850ML Cash Register
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at:
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
I need free manual for Royal ER 145. Recently
Here Goes Program 2 position - enter 102420 att/total key - program 1 position enter o in the departments as non tas enter yy mm dd (09 04 23) hit charge key
enter time hhmm (1500) military time hit xtime depress amout tend key turn off and on and maybe will work for your child...Good luck......have fun
Apr 23, 2009 | Royal Office Equipment & Supplies
HP PSC 2210 keeps complaining about paper jam. There is no paper jam!
For carriage jam try these steps
Remove both the ink cartridges from the All-In-One. also all the papars in the tray
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
Good Luck
Sep 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper jam
Turn printer on,
Disconnected power cord on the back...
Press & hold #, 6 keys while connecting power cord, Keep holding till screen shows reset or shuts down..
Make sure the cartridge access door is closed tightly.
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
48 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
