Question about United Office Equipment & Supplies
Cash Maker's Graham brown
823 n Orange Dr.losangelos can 90069 united States
What voting district is 1117 Ben Franklin Dr. in Sarasota, Florida in?
https://www.sarasotavotes.com/precinctfinder.aspx
Fill in 1117 Benjamin Franklin DR (Don't type Ben -that won't work)
My Districts
Precinct 211 The links displayed below, contain specific information related to your voting precinct (home address). Selecting any one of the links below will display custom election information specifically for you.
President Vice President United States Senator U.S. Senator U.S. Senator United States Representative United States Representative District 16
State Senator State Senator, District 23 State Representative State Representative, District 71
County Commission County Commissioner District 2
School Board School Board District 4
Feb 04, 2018 | Franklin Computers & Internet
I WANT A INSTRUCTION MANUAL TAPE RADIO CD JVC DR-E58 COMPLETE INSTRUCTION MANUAL
Hi there... ABDOU,
Nothing here in the UNITED STATES...
(fixya: San Mateo, California) but found a SINGLE entry
from the GLOBAL Search...
Original Service Manual JVC DR E58 BK DR E59TN eBay
Hope this helps
Carnac the Magnificent
Nov 15, 2017 | JVC Car Audio & Video
Which fuse protects the interior light Hyundai i10 1.2 comfort
hi I have a hyandi i 10 2013 I am trying to fit a remote central locking . But I am having trouble with what wires to connect to where.the remote wires are black pink white green,yellow and purple. and on the switch there is only orange,black,green and brown. I would be greatful if you could help. Thanks Graham
Jan 06, 2013 | 2010 Hyundai i10 1.2
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
Wat do all the wire cables mean at the back of the stereo? e.g.- brown, white/purple.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Brown
Car Radio Antenna Trigger: White
Left Front Speaker Wire (+): Yellow/Red
Left Front Speaker Wire (-): Brown/Orange
Right Front Speaker Wire (+): Black/Red
Right Front Speaker Wire (-): Brown/Orange
Left Rear Speaker Wire (+): Yellow/Black
Left Rear Speaker Wire (-): Black/Orange
Right Rear Speaker Wire (+): Blue/Black
Right Rear Speaker Wire (-): Brown/Orange
Apr 18, 2011 | 1993 BMW 7 Series
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
Heat strip install
What color wire is connected to the "Y" terminal on the thermostat.
If the unit you are connecting is a heat pump A/C unit the orange wire is for the heating mode. Normally the "Y" terminal on the thermostat. "R" terminal on the thermostat is the power to the thermostat, "W" terminal is for heating, "Y" is for cooling, and "G" terminal is for fan operation. At the condensing unit for cooling the brown and yellow wires would normally be for the cooling.
May 21, 2008 | Weather King 10AJA2501AH Air Conditioner
26 people viewed this question
Top United Office Equipment & Supplies Experts
jasbo
jasbo
Are you an United Office Equipment and Supply Expert? Answer questions, earn points and help others
