Question about Zephyr Kitchen Ranges
Zephyr Milano hood is not working. The display is flashing. In tiny letters, it says filter, but this is not the normal "clean filter" display. Turning the breaker off and back on did not work.
3 Suggested Answers
  • 833 Answers
SOURCE: Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Posted on Dec 09, 2007
SOURCE: can't figure out how to
just use an adjustable pliers wide enough to grip the outer small edges. Grip, turn counter clock wise and remove. The other way to do this is unscrew the panel behind the filters and you should be able to reach the neck of the bulbs.
Posted on May 07, 2009
Terrible noise when fan comes on...
The fan is most likely hitting or scraping into something. Disconnect the power and open up the fan panel. Push the fan blade manually and see if it's hitting into any walls. If not it may be the vibrations from the motor. In this case you should tighten any bolts that aren't completely tightened
Mar 13, 2010 | Zephyr Milano ZMLM90 Stainless Steel...
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
Dec 13, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Can't figure out how to get bulbs out of hood to replace on Zephyr Milano-G ZMI-M90G Kitchen Hood
Nov 30, 2008 | Zephyr Milano-G ZMI-M90G Kitchen Hood
Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 22, 2008 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Speed control on fan
It means that the filters on the hood need to be cleaned. You simply pop them out and can wash them in the dishwasher. Once clean, dry and replaced, you hold down the fan speed button (the second button from the left or " - " minus for more than five seconds.) When you first hit the button the A will appear, hold the button when the letter disappears, the timer has been reset until time for the next cleaning. The microprocessor in the system will flash every 30 hours of operation.
May 07, 2008 | Zephyr Venezia ZVE-E30 Kitchen Hood
Flashing "A"
Press and hold the (-) button with the unit off untill the (A) clears. It's a 30 hour timer to remind you to clean the filter
Mar 11, 2007 | Zephyr Venezia ZVE-E42S Kitchen Hood
Kitchen Ranges Logo
64 people viewed this question
Top Zephyr Kitchen Ranges Experts
Tom Chichester
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
