The sound goes up and down between advertisent, and Regular picture.
When I turn on the TV it goes to white fuzz then the regular picture flashes periodically. What's wrong?
sounds like bad ariel connection check that first, sometime water get in cable if its fine on dry days that's it.
Apr 04, 2015 | Televison & Video
TV screen not showing , however sound is working properly
MY TV PICTURE GOES OFF AFTER MAYBE EVERY 5 - 10 BUT SOUND IS ON, IT'S ONLY 14MONTHS OLD 47LG50. WHAT NEEDS TO BE CHANGED OF FIXED? PLSE ADVISE
Jun 02, 2010 | LG 47LG50 47 in. LCD HDTV
My idle is a little shakey as well as very low on 1990 ford truck
check throttle position sensor and or the idle air control valv both are on the throttle body
Apr 20, 2010 | 1990 Ford F150
Window regular goes out on 2 different windows with only 50,000 miles.
Very common problem, i have a customer have 2 go out under 36k miles and fixed under warranty and 1 after warranty. There is a permanent solution, do a web search for jeep liberty window regulator and a repair kit pops up under google advertising, a local shop can install it for you or you can do it yourself
Jul 26, 2009 | Jeep Liberty Cars & Trucks
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
TV sound much louder on commercials
It is Not your TV this is done by advertisers to get your attention and it works
Dec 23, 2008 | Insignia NS- 27" TV27 TV
Xbox 360 sound but no picture
ARE YOU PLAYING YOUR 360 ON A REGULAR TV?
Nov 08, 2008 | Microsoft Xbox 360 Console
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
No picture
You have short in the cables and they need to be replaced.
Jun 26, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Commercial skip/blackouts
Sounds like you're blessed to have a tv like that! Seriously: Some sets have settings that will cut down the sound during a commercial. Haveyou looked at your owner's manual? This tv may have setting to cut out the picture also when commercials come on. From a technical view point generally commercials have stronger signals than regular programming. This may be overloading your set. If this is the case, then you need to have it checked by good technician. A poorly operating power supply (not regulating properly) could possibly cause a problem like this. Also automatic gain control circuits could be not working properly. Stargazer
Jan 19, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
