Question about John Deere Garden
When operating tractor it will slip into neutral then wont shift into forward or neutral and if I set parking brake light indicator beeps like it is in gear john deere 210le
  • John Deere Master
  • 7,515 Answers
You just go to the link I attached I'm sure you will get the solution of your problem.
john deere 210le
Posted on Apr 18, 2017
Why wont my shifter come out of park and lights are out
If it is parked on an incline the best way to get out of park is to fully set parking brake, turn key to the on position but do not start. Should easily shift to neutral and back to park. Start vehicle and shift before removing brake.
Apr 25, 2014 | 2005 Lincoln Navigator
Neutral safety switch
Maybe the Shift interlock cable is your problem from shifting from drive to park but not sure about the reverse.
Mar 18, 2014 | Mazda Millenia Cars & Trucks
2007 Hyundai Santa Fe 2.2 Diesel, transmission went into neutral while driving.
Check transmission fluid level if low on fluid it will suck air and transmission forward clutch can not apply. If fluid is full and clean looking RED in color shift control solenoids are the problem and internal. BROWN and BLACK fluid indicates the forward clutch was slipping and now has no holding power for movement. this case the transmission needs reconditioning.
Nov 07, 2013 | Hyundai Santa Fe Cars & Trucks
Dodge 2500 shifter stuck in park wont shift
check make sure brake lights working if not check brake fuse if fuse good you have a faulty brake light switch which allows when you press on brake pedal the brake transmission shift interlock solenoid will allow shift transmission in to out of park.also check brake transmission shift interlock solenoid fuse and transmission neutral safety switch.
Oct 06, 2013 | Cars & Trucks
Mower doesn't stop when drive pedal released
Chances are your parking brake is out of adjustment. Check to see if setting the parking brake stops the tractor completely from being pushed forward and backward. If not, the adjustment is usually just a nut or two on a rod above the axle in the rear of the tractor. Otherwise it could be that the drive belt is too tight but this would probably lead to a burning smell and not being able to shift in and out of neutral well.
Mar 10, 2013 | Garden
After driving for less than a kilometer, i pulled over to drop off my niece; pulled up the hand brake and set the gear to P (parked) mode. after my niece alighted, i changed my mind about parking the car...
Perhaps the shift linkage has slipped and the car is actually in neutral. Try shifting to a lower gear position.
If the car doesn't move in any gear position, you may have a problem with the shift linkage or transmission.
Jan 17, 2011 | Toyota Corolla Cars & Trucks
No spark to plugs
1990 Buick REATTA Recall ID from NHTSA: 90V164000 Auto Recall Date: 09/06/1990
Vehicle Component: POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:FLOOR SHIFT
Estimated Vehicles Affected: 63964
1990 BUICK REATTA Defect Summary:
TRANSAXLE SHIFT CONTROL CABLE MAY DISENGAGE FROM THE FROM THE FLOOR SHIFT CONTROL WITH LOSS OF GEAR INDICATOR REFERENCE AND SHIFT SELECTOR OPERATION.
Defect Consequence:
DRIVER WOULD NOT BE ABLE TO DETERMINE ACTUAL GEARPOSITION THE TRANSAXLE IS IN, WHICH COULD RESULT IN UNEXPECTED VEHICLE MOVEMENTAND AN ACCIDENT WITHOUT PRIOR WARNING.
Remedy:
INSTALL A TRANSAXLE SHIFT CONTROL CABLE RETAINING CLIP TO PREVENT CABLE DISENGAGEMENT.
Notes: GENERAL MOTORS CORP., 1990 Buick REATTA Recall ID from NHTSA: 91V158000 Auto Recall Date: 09/13/1991
Vehicle Component: SERVICE BRAKES, HYDRAULIC:SWITCHES:BRAKE WARNING
Estimated Vehicles Affected: 18904
BRAKE INDICATOR LIGHT MAY NOT LIGHT WHEN IGNITION IS IN THE "ON" POSITION, THE PARKING BRAKE IS APPLIED, AND THE SHIFT SELECTOR IS IN THE PARK OR NEUTRAL GEAR RANGE.
Defect Consequence:
VEHICLES WOULD NOT MEET THE REQUIREMENTS OF FMVSS 101AND 105.
Remedy:
REPLACE THE PROM IN THE BODY COMPUTER MODULE TO PREVENT THIS CONDITION FROM OCCURRING.
Notes: GENERAL MOTORS CORP., 1990 Buick REATTA Recall ID from NHTSA: 90V031000 Auto Recall Date: 02/12/1990
Vehicle Component: AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Estimated Vehicles Affected: 857
THE FORWARD SENSOR FOR THE AIR BAG MAY HAVE BEEN INCORRECTLY CONSTRUCTED WITH PART OF THE WIRING HARNESS TO THE SENSOR REVERSED.
Defect Consequence:
THE REVERSAL OF THE WIRES COULD CAUSE DELAY IN THE DEPLOYMENT OF THE AIR BAG AND INCREASE THE SEVERITY OF THE OF INJURY TO AN UNBELTED DRIVER IN AN ACCIDENT.
Remedy:
REPLACE FORWARD DISCRIMINATING SENSOR AS NECESSARY.
Dec 03, 2010 | 1990 Buick Reatta
Seabring wont come out of park
check the fuses especially the one(s) for the brake lights. have someone stand in back of car and see if brake lights even work.when you step on brake pedal,you should be able to hear a "click" that is the shift release solenoid letting the shifter come out of park. u might also have a bad brake lite switch or broken/burnt wiring coming off the brake light switch.
Aug 31, 2009 | 2007 Chrysler Sebring Sedan
Craftsman 42 in 19.5 unable to control speed forward motion
is this perhaps a hydro trans? if so, try putting the shift lever in neutral, then let off the brake pedal, use the shift lever to go forward and to neutral to stop - same with reverse, don't even use the brake pedal except for emergency stops. if it's a manual shift, it's possible the belt is incorrect, and/or the belt guides are bent or the belt is improperly routed - the belt guides are important as they allow the belt to "blossom" off the engine pulley, reducing the "shock" load when engaged - hope this helps
Jul 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
