How can I remove tab information on my note 8 screen. It just appeared after a reset
Factory reset for galaxy tab
Method 1: From Startup (Tab 4)
  1. With the device off, press and hold the "Volume Up", "Home", and "Power" buttons.
  2. Release the buttons when you see the recovery screen and the Samsung logo.
  3. Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...
  4. On the next screen, press "Volume Up" to continue.
Jul 15, 2016 | Samsung Galaxy Tab Tablet PC
How can I reset my Galaxy tab 2 7 to its original settings?
Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ...
https://www.androidpit.com/.../samsung-galaxy-tab-2-7-0-how-to-perfor...
Jun 18, 2014 - Samsung Galaxy Tab 2 7.0 - How to perform a hard reset with the ... From the Backup & restore section, ensure the appropriate account is ... In Menu mode, select Settings ? Privacy ? Factory data reset ? Reset Tablet? ... Samsung Galaxy Tab 2 10.1 - How to perform a hard ...
Jun 18, 2014
How to Hard Reset the Galaxy Tab 3 - Android Forum ...
May 7, 2014
More results from www.androidpit.com
Galaxy Note 5: How to Perform Soft & Hard Reset
www.technipages.com/galaxy-note-5-how-to-reset
Aug 23, 2015 - If you want to sell or give away your Samsung Galaxy Note 5, or if you're ... The hard reset will wipe all files off of the internal memory, as well as ... your phone and just perform a factory reset as a way to make it their own. ... November 7, 2015 at 3:44 pm ... I have problem with my Samsung Galaxy tab 2 ...
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0
? 6:01
https://www.youtube.com/watch?v=7sbgN0PxMzc
May 2, 2013 - Uploaded by HARD RESET KING
How to Hard Reset/Factory Reset Samsung Galaxy Tab 2 7.0Android 4.0 ... hi I got the same one as you and ...
Dec 21, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
How do i reset my outlook password
sad to say you need to contact Toshiba tech support
Apr 08, 2015 | Toshiba Computers & Internet
How to get rid of the ask toolbar?
To uninstall Ask toolbar from your computer, you can follow the steps below:
1.To uninstall "Ask Toolbar" program from Windows XP, Windows Vista or Windows 7, click the "Start" button, then click on "Control Panel". If you are using Windows 8, drag your mouse pointer to the right edge of the screen, select "Search" from the list and search for "Control Panel".
2.When the "Control Panel" window opens click on the "Uninstall a program" option under "Programs" category.
(Note: If you are using the "Classic View" of the Control Panel, then you need to double-click on the "Programs and Features" icon instead.)
3.When the "Programs and Features" or the "Uninstall a Program" screen is displayed, scroll through the list of currently installed programs and uninstall "Ask Toolbar, Ask Toolbar Updater, Ask Updater" and any other recently installed or unknown programs.
Once you have successfully uninstalled the above mentioned applications from your system, you also need to reset your browser to remove Ask toolbar and Ask.com from the respective browser. To do this, refer to the steps listed below:
(Important: While resetting your browser(s), go through the on-screen instructions very carefully to understand what all changes will be made in your browser once it is reset.)
To reset Internet Explorer:
1.Open Internet Explorer, click on the "gear icon" in the upper right part of your browser, and then click on "Internet Options".
2.In the "Internet Options" dialog box, click on the "Advanced" tab, then click on the "Reset" button.
3.In the "Reset Internet Explorer settings" section, select the "Delete personal settings" check box, then click on the "Reset" button.
4.When Internet Explorer has completed its task, click on the "Close" button in the confirmation dialogue box. You will now need to close your browser, and then you can open Internet Explorer again.
To reset Mozilla Firefox:
1.In the upper-right corner of the Firefox window, click the Firefox menu button ( ), and then click on the "Help" ( ) button.
2.From the "Help" menu, choose "Troubleshooting Information".
(Note: If you're unable to access the Help menu, type about:support in your address bar to bring up the Troubleshooting information page.)
3.Click the "Reset Firefox" button in the upper-right corner of the "Troubleshooting Information" page.
4.To continue, click on the "Reset Firefox" button in the new confirmation window that opens.
5.Firefox will close itself and will revert to its default settings. When it's done, a window will list the information that was imported. Click on the "Finish".
(Important: Your old Firefox profile will be placed on your desktop in a folder named "Old Firefox Data". If the reset didn't fix your problem you can restore some of the information not saved by copying files to the new profile that was created. If you don't need this folder any longer, you should delete it as it contains sensitive information.)
To reset Google Chrome:
Before resetting Google Chrome, you first need to remove Ask toolbar extensions from it, change your default search engine, and also change the homepage. To do this, refer to the following steps:
To remove Ask toolbar extensions:
1.Click the Chrome menu button on the browser toolbar, select "Tools" and then click on "Extensions".
2.In the "Extensions" tab, remove (by clicking on the Recycle Bin) the Ask Toolbar and any other unknown extensions from Google Chrome.
To change default search engine:
1.Click the Chrome menu button, then select "Settings", and click on "Manage search engines" in the "Search" section.
3.In the "Search Engines" dialog that appears, select "Google" and click the "Make Default" button that appears in the row.
4.Search for "Ask.com" in the Search Engines list, and click the "X" that appears at the end of the row.
To change default Homepage:
1.Click the Chrome menu button, and then select "Settings"
2.Go to "On Startup" section and select "Open the New Tab page"
2.Click on "Show advanced settings" at the end of the page and go to "Reset Browser Settings" at the bottom of the page
3.On the dialogue box that opens, click on "Reset"
Jun 29, 2014 | Computers & Internet
Cannot open my phone after too many attempts entering wrong pattern,and it asked me my google account with crrect password but it doesnt work
1. The device must be powered OFF to hard reset.
Note: If the device is not responsive and does not turn off, remove the battery and re-insert it.
2. Press and hold the Home button and the Power button at the same time.
3. Keep holding Home and Power together for at least 25 seconds, even if the "Startup" screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Slide the keyboard open.
6. As a shortcut, press ALT+W to factory reset the device. If this does not work, continue with the below steps.
7. Press ALT+L.
8. Press Alt+W for 'wipe data/factory reset'.
9. Press the Home + Back key.
Note: You can also remove the battery and re-insert it.
Thanks for using fixya
Oct 12, 2013 | HTC G1 Smartphone
Reset instructions
Hi Michael
1...Make sure you have an Internet connection, you may need to download new updated versions of the iTunes or iPod Software.
2...Download and install the latest version of iTunes.
3...Open iTunes.
Connect your iPod to your computer using the USB cable that came with your iPod.
4...After a few moments, your iPod will appear in the Source panel in iTunes.
5...Select your iPod in the Source panel.
You will see some information about your iPod appear in the Summary tab of the main iTunes window.
6...Click Restore.
7...A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun.
When this stage is done, iTunes will show one of two messages with instructions specific to the iPod model you are restoring.
8...Disconnect iPod and connect it to iPod Power Adapter this typically applies to older iPod models.
Leave iPod connected to computer to complete restore this typically applies newer iPod models.
9...During part two of the restoreing process, the iPod will display an Apple logo as well as a progress bar at the bottom of the display.
NOTE: It is very important that the iPod remain connected to the computer or iPod power adapter during this stage of the restore.
10...After the restore process is complete, the iTunes Setup Assistant window will appear.
It will ask you to name your iPod and choose your syncing preferences.
Please take time to rate me.
Bud
May 02, 2013 | Apple iPod touch
Galaxy p1000 is frozen cant switch off nothing is happening
Hope this helps:
How to Hard Reset Samsung GT-P1000 Galaxy TAB:
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Feb 05, 2011 | Samsung Galaxy Tab Tablet PC
My blackberry 8520 curve gives a message saying uncaught exception : Index 8 >=8 , and then a white screen with the words app error 523 appears
Hi, application errors are usually Virus infected error, You can try and use this reset steps, but it does not work on all black berries.
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Feel free to pass on your comment..
Thanks for using fixya...
Jan 10, 2011 | RIM BlackBerry Curve 8520 Smartphone
Compatability issue
How to install an XP/Vista program on Windows 7
First of all locate the setup or installer file, this will be either in the contents of a CD/DVD (you have to explore the contents of the CD/DVD) under the name "setup" or a downloaded .exe (executable) file.
Right click on the setup file and select "Properties" from the sub menu.
A Properties windows will appear on screen, click on the "Compatibility" tab.
At the bottom of the tab you will see the header "Privilege Level".
Check the box that says "Run this program as an administrator"
Also at the top of the Compatibility tab you will see "Run this program in compatibility mode for:"
Check that box and if you have the option select Windows XP (service pack 3).
Click Apply and then OK and install your program.
NOTE: if you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
How to run an installed program on Windows 7
Some programs will install but they won't run on Windows 7. Again this down to compatibility but unlike Vista, Windows 7 has the compatibility mode working down to a tee.
Locate the desktop icon or the program in "All Programs" from the Start Menu or Orb as it's affectionately known today.
Just as in my tip about installing a program it is just the same.
moz-screenshot.pngmoz-screenshot-1.pngmoz-screenshot-2.pngRight click on the icon or file and select "Properties" from the sub menu.
Click apply and then OK and run the program.
NOTE: If you have upgraded from Vista Windows XP mode may not be available depending on how you system was configured.
Regards.
Jul 09, 2010 | Broderbund American Greetings Creatacard...
How do I rotate the screen when I rotate the Acer B203w
For Windows XP -- within the control panel, click on Display Icon and the following screen will appear. I have 2 monitors (Laptop and HP L1925 monitor). On the display properties screen, near the top of the screen, click on the “Settings” tab. When the “Settings” screen displays, select the “Advanced” button near the bottom of the screen.
The “Plug and Play Monitor …” screen will appear as shown below. From this screen, click on the “INTEL(R) Graphics Media Accelerator Driver for Mobile” tab near the top of the screen. Note: Tab stretches the full width of the screen.
The "Plug and Play Monitor ..." screen will change to show Intel Graphis Media Screen. From this screen click on the “Graphics Properties” button near the center of the screen.
The screen will change to show the graphics properties. Note, the screen actually comes up with “DISPLAY SETTING” selection (in dark Blue on the Left hand side of screen). To change Display settings click on the words “DISPLAY SETTINGS” (left side of screen) and the screen will switch to show Rotation options. On the top of the screen, select the “Monitor” you wish to change by clicking on “Monitor” button. Next make sure the “Enable Rotation” box is check on the right side of screen and then click on “90”. Your monitor should rotate at this point to portrait. A message will appear letting you confirm if you wish to keep this new setting. Specify yes to keep the new setting.
This should do the trick.
Joe Buus
Jan 29, 2009 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
