Question about Boating
Wat are the feulpressure on a seadoo gtx 2004 pls
4 Suggested Answers
heimlich
  • 1978 Answers
SOURCE: hello i have a jet ski seadoo 95 gtx when i pull
You are probably dealing with moisture corrosion in the carburetor. Take out the carb and carefully clean it. Paying close attention to the needle. Be careful not to alter the spring on the needle in any way.
Posted on Sep 03, 2010
SOURCE: 2003 seadoo gtx 4-tec supercharged
Need to kw where the supercharge is on the motor
Posted on Jul 14, 2011
yakoobsheikh
  • 24 Answers
SOURCE: 2003 seadoo gtx 4 tec
temperature switch faulty get it checked
Posted on Aug 16, 2014
How do I adjust seadoo RFI mixture?
There should be an adjustment screw that looks like a "t" on the side of each carb. Screw it in 1/8th turn at a time to lean it out. Too much and engine detonation. I would recommend getting the retrofit kit to block off the oil tank and run mix fuel. Then there are no issues with too lean/rich, oil pump failure, plugged oil filter, broken or collapsed oil lines etc.
Sep 03, 2014 | WSM 1999-2003 Sea Doo Gtx 951 Cc Jet Ski...
Aug 16, 2014 | Cars & Trucks
How do I remove the flywheel from my 98 seadoo gtx ltd.
You need a special puller that threads onto the flywheel and has a screw to push on the crankshaft to pop it off.check eBay, they are only 20 bucks or so
Aug 08, 2014 | Cars & Trucks
96 seaboo will not go full speed in water, but full rpm out of water
carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
Sep 08, 2013 | Sea-Doo US Seadoo sea doo cdi ignition...
Won't start replaced feulpump and feulpressure regulator and still won't what could it be
Did you check fuel pressure at the injectors before and after you replaced the pump ?
And did you also replace the fuel filter ?
Is it getting spark to the plugs ?
Jan 12, 2013 | 2003 Chevrolet TrailBlazer
2003 seadoo gtx 4-tec supercharged service manual
Sep 08, 2010 | Sport & Outdoor - Others
Hello i have a jet ski seadoo 95 gtx when i pull on gas all the way it chocks out on me wat i nedd to do thank you
Jul 08, 2010 | Encore Software Kawasaki Jet Ski...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
