Question about Kyocera Office Equipment & Supplies
I have a kyocera mfp 6525 model .firstly which year model is this? Secondly when I put one paper on ADF it works then when putting more than one paper it stars jaming after scanning one paper .
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 181 Answers
Try replacing your feed rollers or cleaning them specifically your retard roller
Posted on Apr 28, 2017
SOURCE: HP ScanJet 5590 ADF doesn't engage
cannot possible to install in vista using the CD of scanjet 5590
Posted on Apr 25, 2008
SOURCE: After paper jam in the ADF
I found when it doesn't let you scan, copy, etc after a jam if you remove the ram, reset the machine and replace the ram it goes ok until the next jam.
Not the ideal solution but it seems to work.
Posted on Aug 18, 2008
  • 837 Answers
SOURCE: when scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Posted on Nov 24, 2008
  • 2120 Answers
SOURCE: ADF not working
Open the document feeder and look for an obstruction.
Clean the roller and pad with isopropyl alcohol.
Also look for a switch actuator trapped down or knocked off.
Posted on Jan 04, 2009
SOURCE: Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Posted on Mar 11, 2009
ADF of kyocera km-5035 not working
I think you would have looked for paper blocking it. If not check Regards Billy
Oct 11, 2017 | Kyocera Office Equipment & Supplies
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Why is a document not recognized when put into the ADF?
There is a sensor that senses the paper in the ADF feeder and if the paper is not snug it will not recognize it. Open the feeder door and check for any debris and shut it and try it.
Aug 31, 2015 | HEWLETT-PACKARD Hewlettpackard COLOUR...
How i do fix code error 245 for kyocera 6525 MFP
Upgrade to the latest firmware of the FS-6525MFP.
Oct 20, 2014 | Kyocera 6525 Copier
Kyocera KM3530 adf paper jam
Have the rollers replaced -Carl
Apr 29, 2014 | Office Equipment & Supplies
Hp laserjet 4345 mfp cannot photocopy anything because the startup button has a red light
Hi Bridgette.
The red light on the startup-button indicates that the machine is not ready for a photocopy. Usally there is something stuck in automated document feeder (ADF). Take a close look and see if can see something in the paperpath. If no luck, try pushing a A4 sheet manually through the ADF and see if something comes out with the sheet. Usally there is a small piece of paper, a paper clip or a staple stuck in the ADF. If nothing found in the ADF, the Scanner Controller Board is probably broke, and needs to be replaced. Good luck.
Dec 31, 2013 | HP LaserJet 4730mfp All-In-One Printer
I'm trying to fax with my Canon MX310, do the fax papers I'm sending go up or down? thanks
Documents need to be face down if you put them on the glass or face up if you have an ADF (automatic document feeder) for single sided pages.
When you put the document on the glass line up the upper right corner of the page (as looking at the back of the paper) with the marker at the left back corner of the glass. If you are using the ADF, put the paper in such that the bottom of the page goes into the ADF first.
I hope this helps.
Sep 16, 2011 | Canon PIXMA MX310 All-In-One Printer
HP 3035 MFP keeps coming up with a "Jam in document feeder " error message. The offending material has been removed from the ADF and yet the error message will not go away. The device has...
The most common cause for this is a jammed paper sensor flag under the top cover of the ADF where the paper is fed. ( small black plastic protrusion )that should should be positioned at the front of its little slot. I think there are 2 sensors so check that they are functioning properly ( that they move from right to left & then spring back )
May 11, 2011 | HP LaserJet M3035 MFP Printer
43 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
