Question about The Computers & Internet
Draw a flow chart for the logic to calculate the area of the LCD Monitor. 5 3.1.4 Draw a hierarchy chart for the logic to calculate the area of the LCD Monitor.
SOURCE: How to draw 3D bar chart in Flash?
nbmhmnjmn,n,mm
Posted on Jun 18, 2009
onlybrosh
  • 284 Answers
SOURCE: take three numbers & find
if a>b and a>c then max = a
if b>a and b>c then max = b
if c>b and c>a then max = c
if a<b and a<c then min = a
if b<a and b<c then min = b
if c<b and c<a then min = c
Posted on Feb 09, 2011
GeoffW1
  • 3961 Answers
SOURCE: draw a flow chart that adds the first n even positive integers
It would be hard to draw a flowchart here, but it would go something like this
sum=0
input n
1: sum=sum+2
n=n-1
if n=<0 goto 2
goto 1
2: display sum
stop
Posted on Dec 12, 2011
SOURCE: Toshiba LCD TV TroubleShooting
I had same problem, i just replaced the power capasiters on the board an solved it...look for mushroom heads or bottoms on them an swap them out an it should be it. And if thats it then buy the higher temp capasiters so it wont happen again..
Posted on Dec 18, 2011
  • 151 Answers
SOURCE: draw flow chart to accept a 20 number from the user and display the number of odd and even
in the diagram "y" =yes "n" = no
Posted on Oct 08, 2012
8756 machine freezing up and icecream to thick what can it do to change problem
You can adjust the viscosity.
In soft serve and frozen yogurt machines, the logic board X36641SER2Refurbished Gen 2 Logic Board This item is sold with exchange...measures the viscosity of the product by monitoring the amp draw of the beater motor. When the machine reaches the set point, it cycles off and the product is ready. In auto mode, you can only adjust product viscosity, temperature in the freezing cylinder is not monitored.
The power board measures the amp draw. L1 power supplied to the beater motor goes through the power board on the beater terminals. Single phase and three phase units use the same Softech control, so the power board allows for different amp draw ranges. A jumper on the power board determines the amp draw range. Place the jumper on the pin that corresponds to the amp draw of the beater motor when the product is at the desired viscosity.
Setting Viscosity Adjustment
1. Place an amp probe on one of the L1 leads on the beater terminal on the power board.
2. Turn the viscosity adjustment screw to the "MAX" position.
3. With the freezer properly primed, press "AUTO".
4. During the freezing process, draw samples and inspect the product appearance. When the desired product viscosity and appearance is achieved, note the beater amperage.
5. Press "AUTO" to cancel the refrigeration cycle.
6. Using the chart, set what range the beater motor amperage falls into and place the jumper on the corresponding pin.
Viscosity Control Chart
2.4 pin - 1.2 amp to 2.4 amp
5.0 pin - 2.5 amp to 5.0 amp
8.0 pin - 5.7 amp to 11.2 amp
7. Press "AUTO". When amperage reaches the noted draw, turn the viscosity adjustment screw SLOWLY until the unit cycles off.
8. Draw several samples to verify the product and amperage when the machine cycles off remain consistent.
Adjusting Viscosity
To increase viscosity, or make the product harder, turn the dial clockwise towards maximum. Important: The dial only turns a limited amount if it stops turning do not force it.
To decrease the viscosity, or make the product softer, turn the dial counter-clockwise towards minimum. The dial only turns a limited amount do not force it once it stops.
We recommend you only turn the dial about 1 hour on the clock, at a time. Once you have made your adjustment, pull the handle to start a new cycle, when the machine cycles off check the product again.
adjusting viscosity on taylor frozen yogurt machine-5jpt2eusobswb402obrm5sjf-2-0.png
Jun 06, 2017 | Ice Cream Makers
SABC Stores uses an application designed by MICT. The application allows customers to order LCD TV Sets of their specified sizes given by the area of the LCD TV Screen.
Are you looking for someone to do your work for you? Aren't most digital TV's set up as a 16:9 aspect ratio? Does that tell you anything about what the height would be, for every chosen width? However, the standard way of describing the size of any TV (especially wide screen TV's) is to measure it as a DIAGONAL size. In the case of any TV, if you apply the Pythagorean Theorem, then simply SQUARE the width (multiply that dimension times itself), and separately, SQUARE the height, and add those two SQUARED values together, then find the SQUARE ROOT of those two combined values, and you will have the exact diagonal measurement! "In the case of a right triangle (any triangle have one angle of 90 degrees), the square of the hypotenuse is equal to the sum of the squares of the other two sides."
Apr 20, 2017 | The Office Equipment & Supplies
Dec 18, 2011 | Toshiba 42LX196 42 in. LCD HDTV
Draw a flow chart that adds the first n even positive integers
sum=0
input n
1: sum=sum+2
n=n-1
if n=<0 goto 2
goto 1
2: display sum
stop
Dec 12, 2011 | Office Equipment & Supplies
I am trying to divide a whole into a smaller number that is a decimal, any help? The question is 5 divide into o.45
You didn't specify the make and model of your calculator, so I can't give you an exact keystroke sequence.
The calculator doesn't care whether a number is a whole number or not. Just do the division.
On most algebraic-logic calculators, to divide 5 into 0.45, press . 4 5 / 5 =
On an RPN or RPL calculator, press . 4 5 ENTER 5 /
On most algebraic-logic calculators, to divide 5 by 0.45, press 5 / . 4 5 =
On an RPN or RPL calculator, press 5 ENTER . 4 5 /
If you still have problems, please reply to this post specifying the make and model of the calculator you're trying to use.
Mar 14, 2011 | Office Equipment & Supplies
White sceen
the LCD panel is not getting the 5/12vdc from the logic board or the fuse on T-CON board is blown or bad T-CON board, it can also be due to bad 5VDC power supply caps in the power supply and in the logic board.
Please read my guide and look at the pictures at my photobucket.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/he can make you a set of caps for you.
Nov 23, 2010 | Acer V193w LCD Monitor
1 To develop a problem statement. 2. Develop an IEEE standard SRS document. Also develop risk management and project plan (Gantt chart). 3. Identify Use Cases and develop the Use Case model. 4....
Sorry, do your own homework. Do you realize the harm you could cause by getting an IT position after cheating your way through school?
Mar 15, 2017 | Cycling
My monitor getting white when i turned on the system....and every thing is not visible.....please tell me the solution
If you get white glowing screen like the example in my troubleshooting guide, then you need to check the ribbon cable between the logic board and the LCD panel's T-CON board, it can be that the fuse is blown on the T-CON board or the logic board is not sending the 5 or 12vdc to the T-CON board. You need to do visual inpsection for bad connections, caps, etc.
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Sep 28, 2010 | Dell E198FP LCD Monitor
Intermittently shuts off
I know of no manual available for Trutech except maybe a flow chart. If you believe the tac switch is bad, all you have to do is un-solder it and use the remote to turn it on and see if it quits. You will probably have to locate a tv shop in your area that may have a scrap LCD set that he can match and take the tac switch out of. I have not encountered a bad tac switch by normal failure yet, in an LCD set, so I'm wondering how you determined the switch is bad? Please let me know?
Mar 13, 2009 | TruTech PLV1615T 15 in. LCD Television
Computers & Internet Logo
Top The Computers & Internet Experts
Ap12
Ap12
MonsterByte
Level 1 Expert
Kelley Hopper
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
