Question about Beko Washing Machines
Beko proinverter not starting cycle. start symbol flashes when start/pause button pushed the double bar symbol flashes. Any ideas please?
SOURCE: start flashes and will not begin wash cycle
My dishwasher Model is 665 15891790 and the serie #FG3907905. After programing my dishwasher and pressing the start button, it fills with water, but when it is due to start the sensing light comes on. I have notice that the ring under the watering arm on the bottom of the machine seams to be cracked. Could that be the problem for the machine not starting its' cycle. Thank you.
Posted on Jun 05, 2007
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
Posted on Mar 14, 2008
SOURCE: beko wma520s start button flashing will
problem sorted by removing filter drain plug very slowly to empty machine of water and any blocked residue. check drain hose is not kinked. reset machine and rinse through on empty ie no washing.
Posted on Apr 03, 2008
  • 240 Answers
SOURCE: Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Posted on Apr 26, 2009
SOURCE: GE WCVH6260 Front Load Washer
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
My washing machine was switched off mid cycle. Now the start/pause, ready, wash & spin/end buttons are lit up. I have switched it on and off from the mains. No change. It is a beko wm6123w. Please help
Try looking in the troubleshooting section of the products user guide/instruction manual, if you have lost this, you can normally download a copy from the manufacturers (beko) website, this is normally located in the support section of the websites.
have you tried pressing the start/stop button as the cycle maybe simply paused.
WM6123 Washing Machines Beko
Jul 04, 2014 | Washing Machines
How can i turn off key symbol
Hello Lucy and welcome to Fixya.
As far as the "signal" activation or de-activation goes, it should be performed before starting a load of laundry and it is as follow's... 1) Turn the program selector to any program as you would doing laundry. Add your items... 2) When you close the door the "start/pause" light flashes... 3) Press the "menu" button until the signal indicator is displayed and flashes ( a small speaker symbol ) as does the start/pause light. If no buttons are pressed within 10 seconds, the current setting will be saved. 4) Press the "select" button until the desired volume or "off" is reached/displayed. 5) Press the "start/pause" button so the program starts and the setting is saved after the cycle has completed. As for the "key" symbol, your washer has a "child lock" program and the symbol indicates it has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Jun 16, 2010 | Bosch Washing Machines
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Toshiba Laptop SPA 10 -WONT START
that just sounds like the hard drive running, try plug an external monitor and see what happends
get back to us
regards
Nov 27, 2008 | Computers & Internet
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Washing Machines Logo
32 people viewed this question
Top Beko Washing Machines Experts
noel
noel
Chris Hall
Chris Hall
micky dee
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
