Question about Alpine Car Audio & Video
Can I install an Alpine CDA 9831 in a 1999 Chevrolet Malibu?
ampman
  • 98 Answers
SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Posted on Aug 21, 2007
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
  • 3 Answers
SOURCE: alpine cda-w550e manual
I needed a manua for my alpine cda-7897 and went to alpine's website and just type in my unit number under there manual section and there it was in a nice little pdf. file. hopes this helps.
Posted on Apr 04, 2009
  • 11 Answers
SOURCE: No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Posted on Jun 01, 2009
SOURCE: alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Posted on Aug 31, 2009
Want to install an apline stereo into a freightliner columbia
Just follow the Aftermarket Wiring Diagram and you will be fine
Apr 12, 2013 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
Setting up ipod to CDA-9885R
The ipod cable plugs into the rear of the stereo. Here is a link to the installation manual:
http://vault.alpine-usa.com/products/documents/CDA-9885%20OM.PDF
Aug 23, 2012 | Alpine CDA-9885 CD Player
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
Time set
Hello
Try to download its user manual from any one among the folloing links. It will have all details.
http://www.pdfjungle.com/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player-pdf-preview/
http://www.dataentryjobs.us/67948.html
http://www.retrevo.com/support/Alpine-CDA-7998-Car-Receivers-manual/id/23223dj397/t/2/
If you feel any difficulty in downloading the manual, inform me by Fixya comment, along with your email address. I'll send a copy of the manual to your device by return mail.
Mar 10, 2012 | Alpine CDA-7998 CD Player
Alpine cda-w550e manual
Aug 26, 2008 | Alpine CDA-7998 CD Player
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
How to install an alpine cda 9851
Aug 21, 2007 | Alpine CDA-9851 CD Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
