Question about Sony Televison & Video
My sony bravia has a white 2 inch white line down the right side what caused this like the screen is split
  • 3 Answers
SOURCE: Vertical green line on screen
If your set is a plasma, this can be one of two problems : either there is a loose connection (one of many, many connections) between the plasma screen and the driver board, or one of the transistor devices has blown. Try GENTLY applying pressure to the opposite ends of the TV to give it a subtle "twist" (please be careful!). Sometimes moving the set to a different location will produce the same effect. If it's still under warranty, call your dealer. Vertical stripes are a common fault with plasma technology I'm afraid! :-( Next time, go for LCD!
Posted on Apr 14, 2007
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
Marrie
  • 563 Answers
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
SOURCE: 3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Posted on Nov 22, 2008
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
White spots on sony bravia 32" S series
what is the cause for the televisions screen to get white spots that spread
Aug 05, 2013 | Sony BRAVIA Televison & Video
I have a Flat screen Sony Bravia KDL-46S4100. Lines go across the screen horizontally about 6 inches apart. There is distortion especially on the right side mostly on lower right. What needs to be done to...
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Apr 02, 2010 | Televison & Video
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Colored bars on Sony Bravia LCD Digital Color TV Screen
This is a screen tab fault and in most cases will require the screen replacing
Sep 13, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Vertical line on TV
usualy this problem is cause by the lcd drive board.
Oct 09, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
