Cars & Trucks Logo
Joe Russell Posted on Apr 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What codes 12. 33. and 35. mean on a 1991 Jeep wrangler 2.5L?
The engine will start and run i did the key cycle and it show the codes list above.
  • Joe Russell Apr 18, 2017
    yes it is running ok at the moment.
  • jack layton
    jack layton Apr 18, 2017
    It's your decision. Either drive it like it is and hope for the best or replace it? I hate to tell people to replace anything, I can't see anything from here.
    Usually, if a tap test gets it working, you replace it.
jack layton
Level 3:
  • Jeep Master 5,569 Answers
  • Posted on Apr 16, 2017
jack layton
Jeep Master
Level 3:
Answers
5569
Questions
0
Helped
2396781
Points
20059
Code 12-- battery has been disconnected once in so many ignition cycles.
code 33 is ac compressor clutch.
code 35 is radiator fan relay circuit issue. Does the radiator fan work ok?
Are you having problems with your vehicle? What kind of problems?
Testimonial: "the problem i was having the engine wouldn't start wasn't getting no spark at coil and spark plugs and no pulsa at fuel injectors so i did a key cycles to check for codes the check engine light wasn't working so i took a hammer and hit the ECU and the check engine light start back to working and the engine started up."
  • 1 more comment
  • jack layton
    jack layton Apr 17, 2017
    Good job, sounds like ecu problem.
    do i need to replace the ECU?
  • jack layton
    That's what it sounds like or the wiring connector. Is it running ok at the moment?
1helpful
Where can i get a engine control module repair for a 1991 Jeep wrangler 2.5L?
in NO ORDER !
the stickers must match , do not guess.
ebay,? '
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X1991+jeep+wranger+ecu.TRS0&_nkw=1991+jeep+wranger+ecu&_sacat=0
or any auto store that sells CARDONE rebuilds.
Cardone does not sell direct, see the full lest of ECU? only 4 and must match yours.
http://www.cardone.com/find-parts/vehicle-parts-listing?make=Jeep%20Trucks&model=Wrangler&year=1991
yes your code 55 is dead. ecu is dead.
or car-parts.com
http://www.car-part.com/cgi-bin/search.cgi
warning there are
2.5L, USA FED< USA CALIF and CANADA ECU and may be for transmissions. (match the numbers (sticker #)
it does not need programming.
jeeps shows, not in stock. NIS,NLA
Do a 1991 jeep wrangler 2.5L have a ignition control module, crankshaft position sensor and a distributor pickup coil?
posted now 3 times why not just do one post,
answers;
yes, yes and yes.
easy no
where,
well the CKP in on the bell housing at flywheel edge with 3 wires.
CMP is in the base of the distributor cam sync its called, and has small wires exiting the distrubutor and is there.
the ECU is on the fire wall next to brake mc
you fix cars, but are not electric savvy
and no mitchells account,
you cant fix cars lacking those documents.
i see you use fixya to avoid books,
are we your only eyes to books,????
How to install a serpentine belt on a 1991 jeep wrangler with a 2.5 engine without power steering
There should be a sticker in the engine compartment that shows the routing and you should be able to hold the tensioner back with a 3/8's ratchet with a long handle.
2answers
1991 Jeep wrangler it will turn over but it will not start...
If, when you turn on the ignition, you do not see the check engine light come on in the dash then your ecu is in need of repair. The ecu has to energize the relays that send power to the fuel pump and injectors. Until that check engine light comes on, no power will be sent to the relays, thus no start. There are a lot of posts on this site about this, called the delayed start check engine light problem.
94 wrangler dies in gear
You don't need a scanner. If you cycle the key off and on 5 times, the codes will start flashing. Here is a link to jeeps and their trouble codes. There aren't that many in the older OBD-1 systems.
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
If you have no trouble codes, check fuel pressure. Multiport injection is high pressure, above 40psi, but Jeep would have specs.
6helpful
Trouble code dtc 12. what should i be looking at to fix it
code 12 is a normal code when the engine is not running. it means there is no distributor reference. When this code flashes during the key cycle, it is normal.
3helpful
I have a 2004 Jeep Wrangler, when the engines is running the engine light came on and stay on. Why is that ?
It could be as simple as a loose fitting gas cap.
Turn the key on and off 3 times, on the 3rd time leaving it on.
Depending on your system, if you have a digital odometer, an error code will be displayed.
If that doesnt happen, the engine light will start flashing. Start writing down how many times it flashes per interval. It may flash 3, then stop, then flash 4, then stop, and finally flashy just two times. This means it is number 342.
Get online and look up error codes for your vehicle and match it up.
Gas gauge always shows above full with key on . key off goes to empty.
there is a short in the wire going from the gauge to the tank. ck the wiring under the truck from the tank going forward, and ck if anything looks like its rubbing on the wiring harness.
1helpful
2answers
2002 Jeep Wrangler 4.0 When Driving the Engine Dies
Put the key in the ignition and turn it on and off (3) times without starting the jeep, leaving it in the on position count the (1) flashing indicator Light, Eg: (5) flashes, Then there will be a pause, then it may flash (3) times, this is a code #53. Keep your Eye on them and write them down. If you should miss (1) Repeat as many times as needed, Info: A #55 means there are no codes!!
Codes
your jeep showed the done message because as im sure you were turning the key on and off to try to start the car this also the method of doing the self check of the diagnostic trouble codes(DTC) and it prompts done when it is finished displaying the DTC's
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
