Question about Craftsman Garden
Need to know the gas tank capacity for Craftsman model 358.797342 leaf blower
    Top Expert:
  • Craftsman Master
  • 51,143 Answers
WHY ?
Posted on Feb 02, 2018
boscia
  • 163 Answers
SOURCE: gas blower craftsman leaf older modle
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
SOURCE: craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Posted on Apr 24, 2009
#1 Taper
  • 1041 Answers
SOURCE: Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
SOURCE: won't start --has gas--has spark craftsman leaf bower
i have a crafstman blower 358794770 wont start i replaced the sprak plug gas lines and the carb it gets sprak but don't get gas in the cylinder.what's left to do?
Posted on Sep 03, 2012
SOURCE: I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Posted on Apr 04, 2013
I have a Craftsman Leaf Blower (made by McCullough) and the fuel tank is leaking - need a new tank. Model #316-794990, Part #MC 9228-334506. Thank you!
Before you spring for a new tank, check that the leak is not coming from around the fuel lines. If the fuel lines are not soft and plyable then they can not seal with the tank and may be the cause of the leak. They are replaceable and if that is the case you can get fixed up for a few dollars in parts.
Sep 13, 2011 | Craftsman Blower Attachment
Sears Gas powered blower 25cc/1.5 Cu. in 2 cycle 200 MPH/400 CFM Where's the fuel filter, so I can clean it?
I have craftsman 25cc 2-cycle blower-It wont turn over-I put new spark plug and cleaned filter. It dosen"t seem to be getting any gas. How would I know if its the gas filter and how do I put new one on? thanks,mh
Jan 23, 2010 | Craftsman 4 Cycle Blower/Vac
2006 25cc 2 cycle craftsman leaf blower
The smaller line that has the fuel filer on it in the tank goes to the stem on the lower part. The larger line that just terminates shortly inside tank goes to the stem on the top of the carb with the bulb.
Nov 30, 2009 | Craftsman Garden
Just let me know.
Jim
Oct 17, 2009 | Craftsman Garden
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Need bolts for carborator for gas leaf blower model #358
Hello. One way I found to get Craftsman parts is to order them online at the Craftsman website.
CYA, Gator241
Feb 06, 2009 | Craftsman 4 Cycle Blower/Vac
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
